Old 11-29-2005, 08:58 AM
Mango™'s Avatar
Mango™ Mango™ is offline
Lifter knocking, will it get worse
Hello fellow s-10 owners!
I have a 1991 Chevy s-10 v-6 4.3l with 165k miles.
I have a bad lifter knocking and I have tried all the oil addiditives and it will not go away.
I will have to overhaul the moter but money is the issue.
My question is, will it get worse?
I am burning oil, like 1-2 quarts a week.
Thanks guys/girls.
Mango™
Old 11-29-2005, 09:23 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Lifter knocking, will it get worse
when your buning that much oil it's time to either fix the motor or replace it.
So I don't think that you should worry about the lifter noise so mucn
That's my 2 cents worth anyways
Old 11-29-2005, 09:29 AM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
My question is what did you do to that poor 4.3L to get that bad that quick?
Old 11-29-2005, 09:32 AM
Banned
That usually happens when people change the oil once every 3 or 4 years
Old 11-29-2005, 11:53 AM
Ahhh ok, I wondered what it took.
Old 11-29-2005, 02:27 PM
Mango™'s Avatar
No I chage the oil like clock work. This truck was sitting in someones back yard for a year and a half and it was given to me.
I got it running and took care of it. I think when it was sitting there it may of broke or something.
Thanks for the feed back.
Old 11-29-2005, 03:08 PM
Banned
Even though it needs a motor you got quite the deal.
A free truck is always nive, How's the body and the rest of it?
Old 11-29-2005, 03:34 PM
Mango™'s Avatar
Talking Re: Lifter knocking, will it get worse
other than the oil and knocking, the truck runs great. free is good huh.
Old 11-29-2005, 05:17 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: Re: Lifter knocking, will it get worse
Mine turned a bearing with a 100,000.I bought it used though and it's hard to say how it was taken care of.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 11-29-2005, 06:51 PM
Free is the best way to get something! I was wondering, cause we have a 4.3 that is over 1/4 million miles, and quite a few sbc's that are WAY up there in miles, and none of them have lifter problems. I was just intrigued by one that had problems so early in life.
Old 12-02-2005, 03:15 PM
crosscut crosscut is offline
Hey...before you try replacing the engine, let me tell you about a similar problem I had in my jeep engine. I started using more then the usual amount of oil and I had a constant lifter knock issue. I told my mechanic and he suggested replacing the gasket under a panel or part near or associated with the intake/injectors. He said that if it went bad, the engine would suck oil and I 'd get a knock from carbon buildup on the plugs. I had him do it and - voila! No more knock and no more carrying around a gallon of oil in the back. It's worth a try...sorry I can't be more specific about the location of the gasket. I'll try to get hold of the mechanic and see if I can tell you.
Old 06-14-2006, 11:36 AM
Mango™'s Avatar
Well I got a rebuilt long block and replaced it and finally got it to turn over, now I need to time it. It turns and back fires in the carb. How do you time it, 91 S10, 157k miles, v6 4.3l.
New dist, new plugs, new wires, new oil, new trans fluid, new rad fluid.
Thanks
