Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 07-18-2005, 01:57 AM
myblueporsche myblueporsche is offline
Question 944 to 951 can it be done?
I have a great 83' 944 that has an 86' 944 turbo engine in it, however one of the cylinders cracked. I also have a 1985 regular 944 with severe body damage. What i am going to do is take the engine out of the 85' and put it into the 83' but i really would like to keep that turbo power and also i dont want to go through the hassle of converting it all back, so i want to know if i can just put the turbo on the 85' 944 engine. Does anyone know if the engine are identical in parameters? And do you guys think this will drasticaly shorten the life of the engine?
Thanks
Old 07-18-2005, 02:43 AM
pearldrum944's Avatar
pearldrum944 pearldrum944 is offline
Send a message via AIM to pearldrum944
Re: 944 to 951 can it be done?
Thanks
Yes it will. I THINK that the blocks are the same...but the heads are different. You might be able to swap the head off the 951 engine (if it's still good) Don't forget that the 944 tranny probably won't last long either, along with many other parts that will need to be upgraded to accomidate the turbo and the power.
'83 arctic silver porsche 944
My gallery.
A better Porsche forum
Old 07-18-2005, 01:39 PM
zzpza's Avatar
zzpza zzpza is offline
nope, the pistons are different.
j.
'02 BMW 330 Ci Sport
'83 Porsche 924 Lux 140bhp
Old 07-18-2005, 05:44 PM
The settup on my 83' is made for a turbo. It has a turbo trany, new suspension, and a bunch of high performance stuff on it. The problem is just that one of the cilinders cracked. So i just want to throw a regular 944 engine in.
The heads are perfect on the turbo so i was going to put it on anyway.
Does it matter that the pistons are not the same since they will reside in their original engine?
Thanks
Old 07-19-2005, 02:06 AM
zzpza's Avatar
yes, you will be running a way too high compression ratio which will cause the engine to run extremely hot when you are on boost. you'll most likely hole the pistons.
j.
