Register FAQ Social Groups
Old 07-14-2005, 12:56 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
Where is the oil line that goes to the turbo
They told me if I disconnect the oil line to the turbo that it will stop the smoking from exhaust because it will stop the oil from going in to the turbo. Any advice.
1995 GSX RACER
Old 07-14-2005, 12:59 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Where is the oil line that goes to the turbo
That will also destroy the turbo.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-14-2005, 01:01 PM
Re: Re: Where is the oil line that goes to the turbo
Well the turbo is bad anyways. You think it would stop the smoke.
1995 GSX RACER
Old 07-14-2005, 01:50 PM
AF - Advisor
Sure, if that is the cause of it. I say do it at your own risk of course. The oil feed line goes into the top of the turbo center section. Be sure to find an appropriate fitting to block that line so oil doesnt come out though. On a 2g I have no idea what that would be. Some find of an inverted flare or something. For a 1g, remove the feed line at the head and plug the hole with a bolt and one crush washer (should be M10x1.25).
Sounds like a lot of work to prove that your bad turbo is bad
Kevin Jewer
Old 07-14-2005, 02:16 PM
There is sum guy here that has a gst and also theres a mechanic they both told me that it was the turbo.
1995 GSX RACER
Old 07-14-2005, 03:02 PM
1995 GSX RACER
Old 07-14-2005, 09:31 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
So I suppose you could either do as Kevin stated, blocking it off, or I would push you towards just purchasing a used turbo for cheap. They aren't all that expensive. Smoke from the exhaust can be a handful of things, but yes, the turbo is definately one of them. Good Luck!
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 07-14-2005, 09:51 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
This is a dumb idea. If your radiator leaked, would you plug it up and overheat the engine? Get a new turbo for $100
Old 07-15-2005, 01:21 PM
gstclips gstclips is offline
Send a message via AIM to gstclips
are you serious? first off if you cant find the oil lines to your turbo u need to sell your car right now cause u dont deserve it. I highly suggest pulling off the oil lines to your turbo hell, why not pull off the coolant lines while you at it.....let me know how that works for you
THE OFFICIAL AF PIMP! - love EclipseRST[Banned]
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 07-15-2005, 11:28 PM
Sorry to threadjack, but who is that girl in your sig?
Aaron B.
52.7 1/4 second try
6.6 55 meters
Old 07-16-2005, 12:29 AM
george536's Avatar
george536 george536 is offline
he just found the pic somewhere
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 07-16-2005, 11:04 AM
Re: Re: Re: Where is the oil line that goes to the turbo
found it hahaha....dont be jelous george just cause u cant get ladiez to model your car doesnt mean other people cant
1997 Gs-t Eclipse
6 bolt + other toys
Currently 295whp
Old 07-16-2005, 12:04 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: Re: Re: Re: Where is the oil line that goes to the turbo
Dont lie gstclips you know thats you!!! Have you been working out!
lol
Anyways, just like what everyone said you can get a used t25 for dirt cheap. Just have a mechanic install it for you so that you dont f*ck anything up. Let use know how it works out.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
