Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-26-2004, 09:57 PM
ciche ciche is offline
radiator overheating
My 93 Camry Se radiator got overheating today (mileage 90k). I can see the leaking coolant on the radiator and it looks like I had to change it. Is this normal? I bought this only two month. What's the reason cause the problem?
Thanks a lot!
Old 11-26-2004, 10:11 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: radiator overheating
Coolant outside the radiator is not normal. Fill it while the engine is cold and then while the engine is idling and warming up. Once the engine is hot, seal the radiator cap and fill the reservoir to the "hot" line. See if you have a leak somewhere.
Old 11-29-2004, 09:10 PM
gelcol gelcol is offline
Thanks a lot!
if your water resevoir boils ? change the radiator
get the classic copper top with 2 layers radiator.not the plastic top single layer one.
