Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 09-15-2004, 04:42 PM
Boomsly Boomsly is offline
Engine light currently on won't go off
Yesterday I replaced the old champion spark plugs with new Bosch platinum spark plugs (i'm sure they are the right ones for the car) Also I replaced the old Fram air filter with a K&N airfilter. yesterday put about 100km (60-70miles maybe?) and everything seemed to be fine. The engine light wasn't on. Took it to work it was fine. Halfway back home form work the light came on. I have an idea of what it is (the spark plugs) but I don't feel like spending 20 minutes or so on spark plugs (very hard to get to and work with because there in an awkward spot) if it might be the airfilter or something?.....
Old 09-15-2004, 10:11 PM
I tried resetting my cars computer today, while the car was off I unplugged the negative wire to the battery and pressed the brake to release all electricity that may be in the car. I let it sit for about 5 minutes started it up still a check engine light. I did the same thing again drove it around, still a check engine light. then I removed the negative flipped the lights to the on position left the lights switch to the on position with the negative wire off for about 10-15 minutes turned the lights to the off position, reconnected the negative wire to the battery started it up still a check engine light. The gas cap is on tight too. I'm starting to think it has something to with the airfilter maybe? because I don't see how it can be the spark plugs considering the engine sounds fine, actually better becasue since I've done it an annoying noise has dissapeared. Any help at all little or big is greatly appreicated.
Old 09-17-2004, 11:30 AM
Robbie1's Avatar
Robbie1 Robbie1 is offline
Re: Engine light currently on won't go off
Check the gap on your plugs.
Might be a missfire.
Current : 2005 Dodge SRT-4
Last: 1998 Sunfire GT
"Speed costs money.....how fast do you want to go?"
Old 09-19-2004, 09:00 AM
Thanks Robbie but I already got the light out had to take it to the garage to get the computer reset I don't understand why the battery technique didn't reset the computer. Oh well alls better now.
Old 09-23-2004, 03:19 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
OBDII cars (96-up) require a scan tool to clear the codes. Save yourself some money next time and take your car to Auto Zone, they will clear your codes for free. I hear Advance Auto Parts is starting to offer this service too.
Old 09-23-2004, 04:41 PM
Yeah I already went to the garage and got it reset. I live In canada so I can't go to autozone. Canadian tire is selling a tool the can reset the codes for only $145 about $100 U.S. I think I might just go out and buy it.
Old 11-14-2004, 01:39 PM
audiogenik audiogenik is offline
Im having the same problem with my sunfire(02) but the ETC(Enhanced Traction Control) light is on too. Im thinking it may be the air filter too but if not its off to Autozone. Any suggestions ?
Old 12-22-2004, 08:52 AM
Lindsay403 Lindsay403 is offline
Re: Re: Engine light currently on won't go off
My sunfire (and also my parent's van) had that problem, they spent thousands, turns out it was just sensitive to condensation and wanted gas line antifreeze (with respect to the engine light problem) Its worth a shot!
