Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 09-07-2004, 06:45 PM
gmcgough gmcgough is offline
Electrical Mystery
I have a 99 Jetta III Wolfsburg Edition with the following problems.
1. When I turn on the right turn signal it activates both left and right turn signals. The left turn signal works perfect.
2. The cruise control works sporadically. Some days it works great and other days it just wont set.
Any help would be appreciated!
Thanks,
Gregg
Old 09-08-2004, 07:17 PM
boschmann boschmann is offline
Re: Electrical Mystery
The 4-way flasher relay (part of the 4-way switch assembly) also controls the turn signals. They are highly prone to failure. They're not too expansive & fairly easy to replace. Try pulling up on the brake (& clutch if applicable) pedal with your foot the next time it's not working, then try to re-engage the cruise. The vacuum part of the switches are prone to fail.
Old 09-09-2004, 09:57 AM
My turn signal problem went away on its own but I will replace the flasher relay if it happens again.
The cruise control is still intermittent.......I have tried pulling up on the brake and clutch with no success. Today its working great but tomorrow it probably wont work. Very difficult to diagnose.
Old 10-04-2004, 12:57 AM
mnewell mnewell is offline
Interesting...
My girlfriend's car just started exhibiting this same problem tonight. I'll check it out further tomorrow.
Old 10-08-2004, 12:32 AM
bleedvw bleedvw is offline
the turn signal concern is due to the flasher relay/hazard switch. the cruise control concern is very posibly due to the brake light switch. there is currenty a recall open on the jettas for brake light switch replacement.
