Old 04-08-2004, 09:10 PM
hunterr83 hunterr83 is offline
Power Locks and Windows Not Working
Hi,
I took my car to the mechanic's today to get my oxygen sensors replaced. He replaced them, but now I have a new problem. The power locks don't work anymore. That lock switch on the driver and passenger side don't work anymore. I have to lock/unlock each of the four doors manually. It's as if the car no longer has power locks.
The power windows only partially work now. All 4 windows can be opened/closed using the corresponding controls on each door, but the panel for the driver-side, which controls all 4 windows, well, only the two switches (driver side and passenger behind the driver side) work. The other two do not.
I think this was caused by something my mechanic did in the process of changing the o2 sensors. Anybody wanna help me out? The car sucks ass now.
Old 04-09-2004, 09:55 PM
Re: Power Locks and Windows Not Working
Dang, so nobody has ever had this happen to them before? Nobody is even replying with at least a, "I don't know how I would fix that, sorry buddy." Sadness.
Old 04-10-2004, 09:09 AM
deaz's Avatar
deaz deaz is offline
Send a message via AIM to deaz
Check your fuses under the dash for your windows, and check the connections at you control module on your driver side, possibly one of them is the prob.
Old 04-26-2004, 02:56 PM
bmyers75 bmyers75 is offline
I have the same problem.....have you solved your problem yet?
Hey!
Believe it or not, I have the EXACT problem on my car.
I have checked every fuse under the sun and found nothing.....have you solved your problem yet?
thanks in advance!
Brock
Old 04-27-2004, 11:39 AM
Talking The answer is: Multiplex Reset
If you search this site, you'll find various references to the Multiplex System. As near as I can tell, this is a fancy term for a reduced wire wiring harness that uses some form of communication protocol to pass on/off/up/down information to various features of the car.
If you reset this, it should solve your problem (it did mine) .
Procedure:
With the car OFF, set the intermittent wiper to it's mid-setting. Turn the key ON/OFF/ON. This resets the multiplex system. The windows immediately worked and when I went OFF/ON again, the locks came back.
Reference Articles:
http://autos.groups.yahoo.com/group/...d/message/1052
http://autos.groups.yahoo.com/group/...rd/message/421
http://www.automotivehelper.com/topic197290.htm
Good Luck!
Old 04-30-2004, 12:29 AM
Thanks for the feedback. My power locks and windows did start working again out of the blue one afternoon when I was going home from school. I found out what the problem was, though--or so I think. The right headlight for my car isn't water tight, so everytime I wash the car, water gets inside and takes months to evaporate back out. When it gets hot, the water begins to evaporate but with no opening (or one big enough to make a difference) the vapors just got into every crevice inside the apparatus. This was causing my right turn light bulb to not blink until the water was all gone. I guess after a few days, enough water had evaporated out that the wires were working again and so the power locks and windows worked, too. Strange how water causing the right turn bulb not to work caused my power locks and windows to malfunction, as well. I've "fixed" the problem with the water, though. I poked a small hole into the right headlight to allow water vapors to escape. So now the bulb blinks just fine. Strange.
Old 04-30-2004, 09:55 AM
It's great you have a solution!
One thing that many of these cases seem to have in common is water. It was very wet here when my locks went down. Later the next week, my windows ceased to work.
Old 04-30-2004, 08:50 PM
integrasedan integrasedan is offline
isn't that called short circuit, like the water cause a short circuit in the system, then it got reset after it dried...dunno.
Old 08-25-2004, 12:17 PM
wiltontan wiltontan is offline
You guys are great! The reset instruction did work on my 98 Accord LX. I have accidentally shorted my battery and created the same problem. Thank you!
Old 10-30-2004, 09:27 AM
Robohowitzer Robohowitzer is offline
The wiper setting worked...go figure. Thanks.
However, I have had an intermittent lock on driver side rear door for a while. Either works, doesn't or rear slow to actuate. Any suggestions?
Old 10-31-2004, 02:42 PM
henrymv henrymv is offline
The hole in the light is simple short term solution, however you neec to seal it properly....or you will have a larger problem later, becasue when it rains water will find it's way in the hole. My advice is take out the housing and run some sealant along the edges and replace any washers around the light bulb abnd then reseal the hole you created.
Old 11-27-2004, 07:36 PM
Fly91Accord Fly91Accord is offline
Well I didnt work on my 1991 accord ex...figures...noy much works on it
