Re: did i mess that up too?
If you're not sure whether the slot you can see down that hole is the pump, or the drive shaft, just put a measuring tape down there, and mark the tape depth with your thumb right at the surface of hte manifold. then measure the distributor shaft from the mounting face, to the tip of the drive tang. should be the within 1/2" of the same depth. If the tape goes about 8" deeper than your Dist shaft, then that rod is in the pan.
Unless it is an aftermarket type like a Moroso, which has a steel pump-drive collar/connector, and no plastic sleeve, you're probably going to need to drop the pan, even if you can get it out of there, which isn't usually easy. Or, maybe you'll be ok if it is a newer replacemement OEM type, and the plastic sleeve was fresh enough to not crack into pieces and fall into the pan. Unless you want to take the chance that those pieces won't get through the oil pump pickup, and lock up your pump, or break into smaller pieces, get through the pump and into the bearings... Do you have room to lower the pan an inch or so? It doesn't need to come all the way out of the car, just enough to fish around in there with a magnetic pickup tool. I dropped my Big-Block pan far enough to get the oil pump out, change the pressure relief spring, and put it back in... Really wasn't too bad at all.
-Jim
2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4
2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck
1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...).
1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint!
1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now).
