Register FAQ Social Groups
Old 05-06-2003, 05:48 PM
turbcivic's Avatar
turbcivic turbcivic is offline
LS engine swaps
Who has them, what are your times and what are the mods. What extra parts had to be bought for the swap, etc. Just wanna know cause i am planning on getting one and adding a 75 wet shot of nitrous. Comments?
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 05-06-2003, 06:01 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Good swap. Need tranny, linkage, and mounts. If you go obd-1 then you need to wire it as such.
Old 05-06-2003, 06:04 PM
turbcivic's Avatar
Right beside the basics of linkage, ecu, and wiring and mounts. By thw way what tranney. Stock LS tranney or should i source another tranny?
Old 05-06-2003, 06:08 PM
kris's Avatar
This one we are using the stock LS tranny. But b16 tranny would be better.
Other than that, we really didnt need any extra parts, other than the usual, timing belt, etc..
Old 05-06-2003, 06:10 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
It depends on your set up. If goin turbo then LS trans will be good. If you're goin all motor then the b16 trans is nice. Since the gears are short on b16 i would get the ys1 (92-93) gsr cable trans. Otherwise you gonna spin alot with all that torque.
Old 05-06-2003, 06:47 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
im doing a ls swap right now, if u need info just give me a holla. i got a post going about this problem i got, swap troubles, if u wanna read it
Team Lonely Drivers
Old 05-07-2003, 05:56 AM
redmanjd redmanjd is offline
ls swaps are the easyest thing in the world, but if you go b18b it is a little more trouble. i personaly like the b18a cable tranny for the fact of it gives you that better torque out put at low end(for driveability reasons)
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 05-07-2003, 12:09 PM
cyberfelon's Avatar
cyberfelon cyberfelon is offline
Send a message via AIM to cyberfelon
dont mean to steal your thread or anything, but i was wondering about the weight of the b18. if i wanted to autocross would that affect the handling alot?
Id rather be drifting...
Old 05-07-2003, 12:32 PM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
i'm not sure of exact weights but anytime you add more weight in the front (which b series does) you are gonna have more understeer. One tip is to relocate the battery to the hatch area. You can also get a set of GOOD coilovers and counterbalance your car to help dial it out.
91 hatch Si
D16Y8 SOHC VTEC from 96 civic
ghetto short ram intake, HP Racing header, Sprint 1.5" springs, 15" Rota Slipstreams, 195/50/R15 Dunlop Sport tires.
Old 05-07-2003, 01:16 PM
mellowboy's Avatar
No.
Old 05-07-2003, 02:38 PM
its not that much heavier. they drive fine but you could bet a set of integra coilovers because they have the proper spring rate for that motor
95 b18b
Old 05-07-2003, 03:31 PM
turbcivic's Avatar
Cool, i was thinking b18b but i am still up in the air on the tranny. I like the gearing of the y1 but 5 gear is too short. I want an occansional run on the highway so i want a taller final gear. I was thinking maybe stock ls with a 75 shot of nitrous. If i go this and the engine already needs a rebuild, do you guys think i should raise the compression to about 10.5 or 11:1?
Old 05-07-2003, 05:08 PM
if i was rebuilding my engine, i would up it to 10.5
Team Lonely Drivers
Old 05-08-2003, 07:25 AM
11 is pushing it on pump gas. and if you are spraying it i would definitly go with 10.5
95 b18b
Old 05-08-2003, 10:58 AM
mellowboy's Avatar
You can 12:1 on pump gas but its not safe for Nitrous. I knew of someone spraying and he has 11:1 cr.
