| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#16 | ||
Re: 2000 Villager Misfire
Check this video out: http://realfixesrealfast.com/realfix...t_Misfire.html Have you done a compression test on #3 clyinder? ecm on ebay item # 120676620646 150577608489 Enter villager ecm on ebay motors, you should get about 6 pages of ecm's for all years 93-02. Does the distributor shaft have any side to side play? Also check for any brownish dust on the optical sensor. sending pm. Last edited by tempfixit; 04-07-2011 at 02:46 PM. Reason: added link and info |
#17 | |
AF User
tempfixit, thanks for the vid and advice. I actually replaced the distributor a couple of months ago for a sensor problem that was underneath the optical pick-up. I reinspected the distributor last night, and it is still clean enough to eat off of.
As for compression, it is good. Still trying a couple of little things before biting the bullet for an ECM. |
#18 | ||
Did you install a OEM distributor or one off of ebay??? The multiple missfires really makes me believe the CMPS in the distributor is faulty. Have you tried the forum I mentioned in PM? I highly recommend posting there before buying ecm. Last edited by tempfixit; 04-15-2011 at 08:21 PM. |
#19 | |
AF User
tempfixit,
Brand new distributor, not reman. Cranked engine over with cap and dust cover off, no stray spark anywhere. Checking other sources for problem currently. Thanks! |
#20 | |
I have a similar problem. I have a 1999 mercury villager that is showing a random multiple cylinder misfire code and an o2 sensor code. The vehicle has a small leak on the exhaust between the catalytic converters and I'm not sure if this would be affecting the back pressure enough to make the engine throw these codes. Also I replaced the distributor and tried the original placement of the distributor and multiple placements. I am going to get the exhaust fixed and put either b12 cleaner/ seafoam cleaner through the engine and fuel system to see if anything will clear up the fuel system/ make it slightly better. The vehicle runs rough at an idle but runs smooth when reving and at higher speeds above approx 1300+RPM's. Are there any other explanations to why it would be running rough?
| Thread Tools | |
