| Latest | 0 Rplys |
#1 | |
![]() Join Date: Jan 2006
98 Rodeo Timing
Hope this helps.
1998 Isuzu Truck Rodeo LS 4WD V6-3.2L ![]() Locations CAUTION: Incorrect removal or installation of the timing belt can result in damage to internal engine components. For complete Timing Belt Removal and Installation information: See: Timing Belt\Service and Repair |
#2 | |
Re: 98 Rodeo Timing
BULLETIN NUMBER:
IB00-S005 GROUP: INFORMATION ISSUE DATE: FEBRUARY 2000 3.5L V6 DOHC (6VE1) / 3.2L V6 DOHC (6VD1) ENGINES: TIMING BELT INSTALLATION AFFECTED VEHICLES The following models equipped with "Direct Attack" DOHC 3.2L / 3.5L V6 engine: ^1998-2000 Rodeo (UE)/ Amigo(UA)^1998-2000 Trooper (UX)^1999-2000 VehiCROSS (VX) SERVICE INFORMATION This information bulletin outlines the proper steps to index the camshafts with the crankshaft. In the event that camshaft timing has been disrupted, due to timing belt breakage or camshafts/crankshaft being rotated without a timing belt, this is important prior to timing belt installation. Due to the gear-ratio used by each camshaft pulley to drive the camshafts, engine timing cannot be indexed conventionally. SERVICE PROCEDURE IMPORTANT: In the following procedures, the references to 9 or 12 O'clock positions are based on deck plane of the cylinder deck-to-cylinder head mating surface (as viewed from the front of the engine), and NOT RELATIVE TO THE SHOP FLOOR. 1.In the event that camshaft timing has been disrupted, due to timing belt breakage or camshafts/crankshaft being rotated without a timing belt, please proceed to Step 2. Otherwise, continue with Step 22 for timing belt servicing procedures. (after removal of front timing belt covers as outlined in the appropriate Workshop Manual). 2.After cylinder head servicing as outlined in the appropriate Workshop manual, proceed to the following steps. Figure 1 3.Lubricate and install the idler gear. 4.Inspect the idler gear retaining cover for wear. NOTE: There is a 0.039 lubrication hole drilled into the idler gear retaining cover. Always inspect this hole for obstruction. Figure 2 IMPORTANT: Do not use a liquid gasket material on the idler retaining cover. Always replace the retaining cover with a new 0-ring. Be sure to lubricate the 0-ring prior to installation. 5.Install the idler cover and torque (10 Nm, 8 lb ft) the 6 mm bolts (Refer to Figure 1). Figure 3 6.Align the right bank idler shaft alignment marks. IMPORTANT: Align the idler gear dowel pin to its corresponding mark on the idler gear retaining cover before installing the camshafts 7.Use special J-tool to pre-load the sub gear assembly. NOTE: Use special J-tool J-42686. Once the sub-gear has been pre-loaded, install the 5 mm bolt supplied with the tool and insert it into the camshaft from the back of the camshaft gear assembly. Tighten the bolt to lock the sub-gear in place. Figure 4 IMPORTANT: When the sub gear is pre loaded, the teeth on the sub gear should be aligned with the teeth on the camshaft gear. 8.Install the odd bank camshaft(s) into the cylinder head. Figure 5 NOTE: Before installing the camshafts, pre-lube the cam lobes using a suitable molybdenum assembly grease. Figure 6 IMPORTANT: The single dot on the camshaft gears must be aligned with their corresponding marks on the idler gear. Also, do not remove the 5mm bolt holding the sub-gear, until the camshaft journal caps are installed and the bolts are torqued. 9.Install the camshaft journal retaining caps and torque (10 Nm, 8 lb ft). IMPORTANT: The camshaft journal caps are numbered to prevent mis-matching. However, pay close attention when installing the caps on the odd bank cylinders. because the cap arrows will face the front of the cylinder head. Figure 7 10.Place a small amount of RTV sealer on the head surface where the cap contacts the head surface. 11.Repeat Steps 3-5 for even bank cylinders. 12.Align the left bank idler shaft marks (Refer to figure 3). 13.Pre-load the sub-gear assemblies (Refer to figure 4). 14.Install the even bank camshafts and pre-lube the cam lobes using a suitable molybdenum assembly grease (Refer to figure 5). 15.Install the camshaft journal retaining caps and torque (10 Nm, 8 lb ft). IMPORTANT: The camshaft journal caps are numbered to prevent mis-match mg. However, pay close attention when installing the caps on the even bank cylinders, because the cap arrows will face the rear of the cylinder head. 16.Place a small amount of RTV sealer on the head surface where the cap contacts the head surface (Refer to figure 7). 17.Install the cylinder heads.IMPORTANT: When replacing the cylinder head gaskets, be sure to use the correct gasket for each bank. 18.Torque (64Nm, 47 lb ft) the cylinder head bolts with oil applied to the threads using the following procedure. Figure 8 IMPORTANT: Do not re-use the cylinder head bolts. 19.Install odd bank cam pulley and even bank cam pulley (Torque: 98 Nm, 72 lb ft). NOTE: Skip this step if the pulley has not been removed. 20.Install both head covers and tighten bolts (Torque: 9 Nm, 7 lb ft) NOTE: Use only a couple of bolts to register the cover. 21.Rotate the crankshaft until the mark on the crankshaft sprocket aligns with the mark on the oil pump cover. This will position the # 2 piston at TDC. (figure 9) Figure 9 22.Time the camshafts on the odd numbered bank cylinders (passenger side), by rotating the odd bank camshaft sprocket until it springs to the 12 o'clock position. (figure 10) NOTE: It may require up to 9 revolutions. Figure 10 IMPORTANT: Due to the loss of the reference timing, you will have to rotate this camshaft sprocket until the timing mark on the camshaft sprocket "springs" into the 120 'clock position. This may require up to 9 revolutions. If the camshaft does not spring to the 12 0 'clock position, camshaft timing will be incorrect. Figure 11 23.Time the camshafts on the even numbered bank cylinders (driver side), using the two step process. (a)Rotate the even bank camshaft sprocket clock-wise until the cam sprocket "springs" to the 9 O'clock position. (figure 11) Figure 12 (b)Rotate the even bank camshaft sprocket an additional 90 degrees (clockwise) to the 12 o'clock position and align the camshaft sprocket mark with the mark embossed on the cylinder head cover. (figure 12) IMPORTANT: Step 23-b is necessary to achieve the correct camshaft timing for the odd bank of cylinders. Failure to perform this last step will result in incorrect valve timing. NOTE: Install the timing belt following the procedures outlined in following steps. Make sure that timing marks are not disturbed during this operation. After installing the timing belt, make sure that all the timing marks are in their proper position. It is very easy to mis-install the belt and be off a tooth, which could cause driveability problems. 24.With the timing marks in their proper position, position the timing belt with marks, noting the direction of rotation. Figure 13 Figure 14 NOTE: On the timing belt, there are series of green arrows indicating the direction of rotation. There are also two solid white lines and one dotted white line. Ins tall the belt with the solid lines perpendicular to the marks on the camshaft sprocket. (figures 13 and 14) Figure 15 Figure 16 25.Secure the belt to the camshaft sprockets using binder clamps. This will keep the belt in the proper tooth of the sprocket and will assist in holding the belt in place. (figures 15 and 16) Figure 17 26.Align the dotted-white line of the timing belt with the white timing mark of the crank sprocket (180°from TDC timing notch). Slip the belt into place and install the belt tensioner (remove retaining pin afterwards). (figure 17) Figure 18 27.After installing timing belt make sure that all the timing marks are still in their proper position and have not been disturbed during the tensioning of the belt. (figure 18) IMPORTANT: If you have resistance while rotating the engine by hand, do not continue. The valves may be contacting the pistons due to incorrect valve timing. Recheck the camshafts and crankshafts sprockets to be sure they are correctly aligned with their marks. Serious engine damage could occur if the belt is improperly installed. 28.Remove the binding clips. 29.Rotate crankshaft pulley a minimum of 2 complete turns (clockwise) and inspect if the timing marks have returned to the same position (# 2 Piston on TDC). If it has returned to the same position then continue to Step 31. If there is resistance, please refer to the IMPORTANT note stated above. 30.Proceed to the remaining reassembly procedure as outlined in the appropriate Workshop Manual. |
#3 | |
Re: 98 Rodeo Timing
more 98 info.
V6 VALVE ADJUSTMENT AFFECTED VEHICLES 1998-2000 VehiCROSS (VX) / Trooper (UX) / Rodeo (UE) / Amigo (UA) V6 models with "direct-attack" valvetrain. For the above affected vehicles, periodic 60,000 mile valve clearance inspections are not required. Adjust if valve noise is evident or a rough idle condition exists. NOTE : When checking valve clearances, adjustment is required only when the clearance (lash) is out of specification. Be sure to retorque the camshaft bearing cap bolts before checking and adjusting the valve clearance. NOTE: To adjust valve clearance, apply engine oil to the cam as well as to the adjusting shim (2) with the cylinder head built on the cylinder block, give a few turns to the camshaft by means of timing pulley tightening bolt, and measure valve clearance when the nose of cam is just opposite to maximum cam lift (1) as shown in illustration. Valve Clearance Standard Value (Cold) Intake: 0.23 mm - 0.33 mm (0.0091 inch - 0.0130 inch) Exhaust: 0.25 mm - 0.35 mm (0.0098 inch - 0.0138 inch) Selection Of Adjusting Shim Shim to be selected = (Thickness of removed shim) + (Valve clearance measurement - Standard value) Based on the above formula, the best suited shim should be selected from 41 sorts of shim (differently thick at 0.02 mm (0.0008 inch) intervals from 2.40 mm (0.0945 inch) through 3.2 mm (0.1260 inch) thick). Install the shim and check valve clearance. Replacement Of Shim Let the cam push down the edge of tappet by using J-42689 valve clearance adjusting tool and push out the shim with a flat blade screw driver as shown in illustrations. |
