Old 07-22-2007, 05:15 PM
chiliwillc chiliwillc is offline
Re: Crazy Signal/Hazard problem 2005 Grand Am SE
I cleaned my switch and it don't click no more but now my horn don't work,any suggestions?
Old 07-23-2007, 08:14 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Sounds like you horn wire may be loose or damaged.
Could check the fuse as it might be blow.
and Welcome to AF.
1999 Grand Am SS 3.4 OHV
Old 07-23-2007, 08:24 AM
BNaylor's Avatar
BNaylor BNaylor is offline
I bet he did not properly index the spring loaded contact on the multifunction switch with the slip ring aka clock spring. The horn signal (ground) passes through the MFS. When installing the MFS you must push in on the contact and make sure it contacts the facing of the clock spring before securing the MFS with the 7mm screw.
Timeslip 08/12/06
AF Community Guidelines
Old 07-23-2007, 11:34 PM
Turns out I damaged the clock spring,it was not getting good contact.Had to replace it.
Old 07-24-2007, 09:29 AM
Yea that was what I meant the clock spring.
If that is not indexed right it will break,
and replacing it is a pita!
