| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Show Printable Version | Email this Page |
#1 | ||
Iridium or not to Iridium
I just took possession of my Talon last night... but I noticed it seems to have awful idle (No CEL) and a slight miss...
I know the battery is dying (car has sat awhile)... but I was told it has iridium plugs in the car... I have heard that these are terrible for DSMs... I think it's time to change them... The car is boosting 17psi on the stock turbo... what plugs should I get(same or 1 range colder)... and what gap should it be set at? look at my sig for other mods...
1991 Eagle Talon TSI - Broken Head removed, block broken, trans in hatch ![]() 1991 Eagle Talon TSI AWD- in pieces 3" exhaust, rebuilt bottom end Project: Assemble the Eagle is underway... and now with AWD 2003 Lancer Evo 1630hp/1593ft lb tq |
#2 | ||
![]() Join Date: Jan 2005
Re: Iridium or not to Iridium
Iridium is OK, but not preferred. It works better in the N/T cars.
Get some NGK BRP7ES and gap them to around .028, and you should be good to go.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
#3 | |
AF - Advisor
Platinum is what turbo car owners should avoid like the plague. Iridium is definitely ok. The EVO comes stock with NGK iridium 7s. They aren't really necessary though, mainly just good for longer life than copper plugs. Copper plugs are so cheap though, we should really all just be swapping them every 1 or 2 oil changes anyway. I run colder plugs, so I change them every 2500 miles with the oil. Only like 7 bucks for 4 of them, especially if you buy by the case. NGK BPR7ES should be right up your alley, with a 028 gap.
Edit> Just noticed eclipse already gave the plug type and gap info
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#4 | |||
#5 | |||
... I was actually getting iridium and platinum mixed up... I was fearing for my dsm... lol... I don't feel so bad now though, I do think I have spark blowout though... b/c the car will boost up to say ~14 and then the car tops off... then I usually shift and let it blow off...
#6 | |
Stay classy San Diego
![]() Join Date: May 2005
Also, I was using some Denso's for a while and they weren't seating correctly with my plug wires, it's happened with another brand of plugs before. I only use NGK plugs and wires now because of the fit.
When I had those crappy plugs on there my car was doing some of the same things yours is doing.
1991 GSX 2.3 Stroker |
#7 | |
#8 | |||
hey, pm me with paypal details and pics on that BOV... I want a different one (crushed stock for now)...
#9 | |
Jizzed In My Pants
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
I dont think spark blow out is the reason to avoid platinum in a turbo car. Turbo cars make much more heat than NT engines and IIRC it actually melts the soft platinum and it drips down into the cylinder.
#10 | |||
When they put the car back together, the vacuum hose on top of the BOV never got reconnected... The car wouldn't boost over 10psi... put that hose back on, and the car's fast as hell
#11 | ||
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
#12 | |||
#13 | |
AF - Advisor
The problem with the iridiums may have been the gap. They are difficult to gap properly due to the nature of the plug. I ran them on the EVO down to 12.0 at 114, they seem to work fine for me. Who knows.
#14 | ||
#15 | |
AF - Advisor
I've never seen a pregapped plug that I've been able to use. I always have to close the gap some. Most plugs are pregapped for NA cars. But if it was pregapped to the right value it may have been something else. I defintely wouldn't say that the EVOs have better spark either, crusty old 1g coils/ignitors are a big upgrade for the EVO! Go figure. I'm ont disagreeing with you either, just thinking out loud.
