Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-01-2005, 04:38 PM
y2cam y2cam is offline
Blower Fan and Head Lamps
I have a '98 Grand Prix GT. Periodically, my HVAC fan will go out all of a sudden and will only work on Level 5 (highest setting). When the fan goes off, my headlamps simultaneously go off as well. The headlamps will go back on when you switch the fan off or onto level 5. (You can actually hear the headlight switch on and off.)
I noticed there is a fuse the controls the low speeds of the blower fan as well as the headlights.
I already replaced the resistor twice so it's not that.
Any help would would be greatly appreciated.
Old 08-01-2005, 08:53 PM
y2kpa2's Avatar
y2kpa2 y2kpa2 is offline
Village Idiot
Re: Blower Fan and Head Lamps
check your owners maual and look for curcuit breakers that may be connected to those same systems
My Fleet 2000 F-150, 2012 Chevy Impala LTZ
Old 08-04-2005, 01:51 PM
riverajesus riverajesus is offline
Red face Head Lamps And Air Condition
I have exactly the same problem but my car is a GP 1999. I change the blower resistor but the problem still. If any body have an idea please let me know.
Old 08-04-2005, 04:22 PM
It's weird. All of a sudden the blower goes off and the daytime running lights click off (it's a pain at night since you have no headlights until you turn them on manually).
The heated seats, driver's information center, rear defroster, as well as the HVAC and daytime running lamps run on the same electrical system. I can't figure it out. It will work for a while and then turn off without warning.
Old 08-05-2005, 03:32 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
check all your battery connections and grounds first, as unless you have a bad underdash harness, the systems you are having problems with are unrelated, both in location and fuse circuit.
Old 08-05-2005, 08:50 PM
According to the owner's manual, the electrical systems I mentioned are controlled by the same fuse circuit. So you think it might be a bad harness?
Old 08-05-2005, 09:32 PM
glennpence glennpence is offline
Blower Fan and Headlamps
I too am having the same exact problem with my *97 Grand Prix. I have had the resistor changed, fuses and relays checked and nothing worked.
My mechanic has pin pointed the problem to a "small electronic contol box" under the steering column with several wires plugged into it. I can move it and the lights and fan motor will work for a few minutes, but after shutting off the engine, the problem returns. Does anyone know what this module might be, or does this sound familiar?
Old 08-06-2005, 11:39 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Blower Fan and Headlamps
The part you are referring to is the ignition switch control module and harness. It is all one piece less the key tumbler.
Here's a pic of it:
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 08-16-2005, 06:05 PM
Rey72004 Rey72004 is offline
I am having the exact same problem, as well.
I have a 2001 GTP and it is behaving just as you describe.
Please help...
Old 08-15-2006, 11:08 PM
bcomstock bcomstock is offline
I realize that this issue is from last year, but I just had the same issue and was able to fix it myself with a bit of "hillbilly engineering" and wanted to share my solution. My 2000 Grand Prix (SE 3.1 engine, manual HVAC controls) has had numerous electrical issues (power windows stopped working and radio stopped working) and I was able to fix them all by running a jumper in the fusebox from a working circuit to the malfunctioning circuit. For example for this specific issue I made a small metal jumper (flat strip bent to "U" shape and inserted into fuse slot along with fuse) to give power from the "Canister Vent" circuit to the "HVAC Control" circuit, and everything works fine. I tried to add a picture but I don't think it worked. Feel free to e-mail me at [email protected] if anyone has questions. Hope this helps someone else. I just can't imagine what a dealer would charge to fix their crappy design/quality.
Old 09-07-2006, 02:47 PM
gpgt98 gpgt98 is offline
In an earlier post Bnaylor mentioned that the time to fix the ignition switch control module and harness was 1 1/2 hours. Is this an estimate for the "experienced" mechanic or an average joe that has the right tools?
Old 09-07-2006, 04:57 PM
richtazz's Avatar
resurecting and old thread is a bad idea. The moderators frown on it, and it makes things hard to track. Please start a new thread on this issue. I'm sure when they see it, they will close this one.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-08-2006, 01:48 AM
BNaylor's Avatar
Somehow we missed this one Rich. The thread was resurrected by the previous poster bcomstock. On bringing up old threads AF rules are fairly clear. We prefer that it not be done. The best thing to do is make a new post which normally gives better visibility and response.
As to the question asked, the 1.5 hours is what it took me. Time to repair will vary depending on whether you are an inexperienced or experienced DIY person or even auto tech. The Mitchell's guides allocate 1.9 man hours to replace the ignition switch and harness and that is for Pros. One factor is to have all your supplies and proper tools on hand ready to go.
In the meantime rules are rules. Thread closed.
Timeslip 08/12/06
Closed Thread
