Old 12-01-2004, 07:21 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
Re: 4 headlight mod
Is the mod worth the time? Does it make that much difference at night?
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 12-01-2004, 10:00 AM
chuck16's Avatar
chuck16 chuck16 is offline
Re: 4 headlight mod
Jayson, Takes a bit of getting use to but, now I couldn't imagine not having the mod. It's great because I found that when you flicked to High Beam, in the stock setup, you lost a little bit of close vision. Now, after the mod, you get what's close and what's really far away.
I wired it easily enough so that if I didn't like it I could just de-Jumper what I had done.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 12-01-2004, 11:54 AM
jeverett's Avatar
Re: 4 headlight mod
Hmm. I just might give it a try.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 12-08-2004, 08:03 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: 4 headlight mod
I had mine apart/tapped/grounded/back together in 15 mins.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 12-09-2004, 07:26 PM
kenny-1907's Avatar
Re: 4 headlight mod
What i like best about this mod is the added brightness. I have screwed up eyes ,my left eye is near sighted and my right eye is far sighted and each eye sees the same thing at different levels. This makes driving at night on the highway with brights on a little tuff because my right sees great at distances with the brights, but my left which focuses closer and lower sees blackness and this really gives a screwy feeling especially when both eyes try to focus on the same point. With this mod it allows my high and low beams to be on at the same time, making both eyes happy lol, not to mention makes it safer. Oh and you all cam breath a sigh of relief, i have never been in an accident and i do not get this sight problem with just the low beams on lol.
6" Pro Comp lift
K&N FIPK GENII
Old 12-13-2004, 06:41 AM
thoot12 thoot12 is offline
Fog light override
Can something like this be done to keep the fog lights on when the high beams are on?
Trey
Old 12-13-2004, 09:08 AM
chuck16's Avatar
Re: 4 headlight mod
OK before I get burned. Somebody pointed this out to me that the Fog lights may be programmed to stay on with the High Beams but, it must be programmed at the dealer.
To avoid that. Throw out your stock fog light switch and put in an aftermarket one. Then wire your fogs with a relay to come on whenever you want them too. I've got mine wired to a S/W'd 12V source so that as soon as the Truck is in the run position I have full control over my Fogs. Trouble is they don't throw a lot of light, I'm shopping for better replacements the moment they burn out...Can't believe I spent $145 (CAN) on such crappy lights...
2008 GMC ACADIA
I AM Canadian!!
Old 02-01-2005, 05:15 PM
sparrbq sparrbq is offline
Thanks
Sounds good, I think I'll try it when we get a warm day.
This voids out the warranty I guess right?
Old 02-03-2005, 09:15 AM
jrn5898 jrn5898 is offline
Re: 4 headlight mod
Originally Posted by FirehawkNS
Has anyone tried to do a 4 headlight mod to a 2000 model Silverado? I did it too my Z and want to do it to the Truck. For those that don't know, when you turn on your highbeams, the low beams cut off. With the 4 headlight mod, the low beams stay on with the highbeams!! Just curious if anyone knew off the top of the head which wires to jumper on the truck too make this work.
I did this with my 94 and painless & summit make a kit that runs about 20 Bucks it comes with relay and wire & wire diagam it take about ten min.
Old 02-04-2005, 09:41 PM
silveradoman silveradoman is offline
Re: 4 headlight mod
I think this is for everybody´s benefit....
http://www.danielsternlighting.com/t...dvantages.html
Old 02-05-2005, 09:36 AM
ryanszpara's Avatar
ryanszpara ryanszpara is offline
Send a message via AIM to ryanszpara
hey guys, sorry to be a dumbass but i did the mod and it woked for like a day....then quit.
I checked my ground and it seems to be okay....im goin to use solder this time instead of a wire tap.....anyone else have this problem??
THanks
-Ryan
2002 Chevy Silverado
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FM 40 Series-dual turn downs
FUTURE PLANS:
3 inch lift
285/75 r16 BFG A/T s
Wheels? (american racing)
Old 02-05-2005, 01:17 PM
ryanszpara's Avatar
so i found my problem, bad wire tap. I soldered instead, works extremely well, and i love it .....
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FUTURE PLANS:
3 inch lift
Old 02-05-2005, 03:15 PM
Sonny01's Avatar
Sonny01 Sonny01 is offline
Re: 4 headlight mod
I installed a set of factory fog lights but then found out that it's 100.00 for the dealer (spits on floor) to program then into the computer. Is there a way to just have them come on with my high beams?
Sonny01
Old 02-05-2005, 09:03 PM
silveradoking silveradoking is offline
is it?
Is it $100 dollars (spits on floor again..) to program the foglights to work or to program them to turn on with the high beams?
Old 02-06-2005, 09:50 AM
ryanszpara's Avatar
i really have no clue what im talkin about, but it seems to me that you could ground them allong with the hi-beam ciricut couldnt you?? Maybe after some hard work looking through some wire diagrams......
Ryan
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FUTURE PLANS:
3 inch lift
