Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '88 - '91 Civic | CRX | Wagon | Shuttlee
Old 01-08-2005, 11:19 AM   #1
Lookin4aTruck
Exclamation Need Info On Thermostat Lots Of Probs
Hey guys can someone post info on the easiest way to install a thremostat on a 91 civic dx? Just picked up a new one and so far I've changed the fuel filter, distributor, rotor button, plugs and have probably spent 500$ plus on a mechanic after the problems got to be too much for me to fix myself. This car has been lots of problems and after loosing coolant the mechanic found a leaking head gasket on the lastest inspection.
Anyway the latest ordeal the heater is not working right. It will get hot sometimes and sometimes it doesn't. When it does get hot it only last for a couple of minutes then its cold again. Not even enough to use the defrost on a cold morning. I bought the POS just for a work car to drive and save on my Dodge Hemi but its getting to where I can't even do that.
I figured it was the thremostat causeing this latest problem although the mechanic said could be the heater core stopped up as well or maybe even the head gasket which doesn't make any sense to me.
I also bought some of that head gasket repair shit in a bottle but the mechanic said not to even put it in the car it had been known to cause lots of problems.
I am just keeping lots of coolant in it I don't think it is leaking too badley. So I know the reason its not heating isn't lack of water. The mechanic also said the motor was in bad shape are probably worn out. He said the rings were bad and lots of oil was leaking past them.
The mechanic said it would be around 200 to 250$ to put in another gasket and the head was probabley warped to. I thought that was too high.
I am just keeping it full of Rotella T and Prestone and run it as long as I can get by with if I can get this heater working.
Lookin4aTruck is offline   Reply With Quote
Old 01-08-2005, 12:55 PM   #2
91civichatch2571
91civichatch2571's Avatar
Send a message via AIM to 91civichatch2571
dude, your heat isnt going to work right if you have a blown headgasket... your lucky the thing still drives.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
91civichatch2571 is offline   Reply With Quote
Old 01-08-2005, 03:39 PM   #3
amy@af
Traffic Directing Admin
amy@af's Avatar
Send a message via Skype™ to amy@af
Re: Need Info On Thermostat Lots Of Probs
that sounds about right for a head gasket install. i once had my head rebuilt and the gasket replaced (also water pump and thermostat) and it was $400. the mechanic ended up over torquing the head and it blew the brand new gasket within a month. looking back i think it would have blown again anyways. my stuff was warped and he sent the head off to be re-cut. so they slapped the straight head on a warped bottom. it would have been better off sticking the warped head back on as it would have at least gotten a better seal with the head gasket.
to be flat honest you could change the head gasket yourself. you could get the head rebuilt and cut. you could have the bottom dealt with as well. in the end it will be a lot of money in parts, even if you do the labor yourself. it would be much more cost effictive to buy a replacement engine.
crx manual: http://www.binghamtonlife.com/manual/manual.htm
if you click that link you will find from replacing the engine to replacing the head gasket to the rings. check it all out, that way you at least know what your mechanic is talking about and you know first hand what all is envolved.
feel free to ask more questions. sometimes you can learn a lot from others experiences and mistakes
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
amy@af is offline   Reply With Quote
Old 01-08-2005, 04:11 PM   #4
Lookin4aTruck
Thanks guys. Thats what I'm here for to learn. And I sure have learned alot about working on cars since I bought this one!
Its been a learning experience for me though and isn't all bad. I still would like to know the local of thermostat.
Dude just cause head gasket is leaking some doesn't mean its lucky to be runnin. Its been runnin fine for a good while like this. But I don't know about the repair in the bottle. I've known people who've used it and lasted several thousand miles.
I looked at some engines at Nippon motors they were like 375$ Probably be more cost effective to go this route but I;m not sure if I could swap the engine out myself.
Oh well, I bought a bad car what can I say the guy saw me commin. I'm gonna check out your link for info
Thanks again.
Old 01-08-2005, 04:20 PM   #5
quiXilver
quiXilver's Avatar
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
I'll buy it from you for $500
But if not, the thermostat is right under the distributor, follow the lower radiator hose around under the distributor, and it'll go right into the thermostat. Two 10mm bolts hold it in, take off the lower hose, then undo the bolts and bam. Easy as pie.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
quiXilver is offline   Reply With Quote
Old 01-08-2005, 04:33 PM   #6
amy@af
amy@af's Avatar
Re: Re: Need Info On Thermostat Lots Of Probs
more specifically:
Old 01-08-2005, 04:36 PM   #7
amy@af
amy@af's Avatar
Re: Re: Re: Need Info On Thermostat Lots Of Probs
check warpage:
whats envolved with head gasket:
Old 01-08-2005, 04:38 PM   #8
amy@af
amy@af's Avatar
Re: Re: Re: Re: Need Info On Thermostat Lots Of Probs
of course you can put it in. there is a section on engine replacement. give yourself 2-3 days.
day 1
pull it all out. lable hoses & wires if you think you'll forget. mount tranny to new block. bolt it back in and call it a day
day 2
hoses, wires, suspension all back in. turn key and drive.
day3
you can take this day off for any freak things to go wrong but i doubt it will be needed. so go for a drive
Old 01-08-2005, 11:18 PM   #9
91civichatch2571
You should really do it yourself if you think your up to it. Its quite a learning experience. Just get a couple of friends to give you a hand and I bet you can do it.
ZC stuff
Old 01-08-2005, 11:23 PM   #10
quiXilver
quiXilver's Avatar
Re: Re: Re: Re: Re: Need Info On Thermostat Lots Of Probs
day 1
day 2
day3
Lol she makes it sound so easy.. It's really not that bad if you're just doing a SOHC replacement swap.
B18A
Old 01-08-2005, 11:35 PM   #11
amy@af
amy@af's Avatar
Re: Re: Re: Re: Re: Re: Need Info On Thermostat Lots Of Probs
it is easy when you're just doing a replacement. it's when you have to tackle wiring for a swap that it sucks.
i recently posted this in another thread about a couple of engine pulls in a day:
9:45am started pulling engine from rolled 95 sedan dx and then started pulling a bad engine from a 92 dx. with both engines out we took lunch at 1:00pm. took an hour for lunch so returned at 2:00pm. dropped the good 95 engine into the 92. the 92 was turn key 4:30pm and went out the door 5:00pm
my y8 was our first engine swap of any kind we had attempted. we hadn't even done a replacement engine yet. we got it done easily in 2 days. but my y8 cap was busted and i couldn't get another. so on day 2 we ended taking out the y8 dizzy and tried my stock si dizzy. it didn't work so we called it a day. after sleeping on it we realized that the si dizzy wasn't compatable with the p28 ecu. put the pm6 back in and it fired right up.
putting in a replacement engine isn't dealing with all that so i don't see why 2 days isn't enough...3rd day to be extra careful.
it is an excellent learning experience as 91civichatch2571 mentioned.
Old 01-09-2005, 05:44 AM   #12
Lookin4aTruck
Is Nippon the best place to get a replacement online? I may tackle this guys now that I have some more info. Thanks for the help I am gonna check it again today and put the thermostat in just to see what that does.
Something I don't have is a good jack to lift the old stuff out with.
Old 01-09-2005, 06:07 AM   #13
Hybrid1990crx
Hybrid1990crx's Avatar
Yeah doing a motor replacement is really easy. As for the headgasket is pretty easy too. I've done both. And also have done a few swaps too. All it is, is turning bolts and clicking the harness. And we can help you out with anything you need info wise.
Hybrid1990crx is offline   Reply With Quote
Old 01-09-2005, 11:13 AM   #14
amy@af
amy@af's Avatar
nippon has been around for years. if you're in so cal kwantabe has been around for ever as well.
Old 01-09-2005, 11:18 AM   #15
Lookin4aTruck
No babe, I'm all the way over on the East Coast.
