Go Back   Automotive Forums .com Car Chat > Ford > Windstar
Old 06-12-2013, 01:34 AM   #1
searcherrr
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Exclamation Looking at 2002 Windstar LX to buy
Anyone have any quick advice about the low points of a 2002 Windstar LX? It has 135k miles on it.
Today I went to look at it and promised to buy in 2 days.
I found the following:
Cons:
  • Brake light on (fluid at minimum marked level); what are possible reasons for brake light? I checked the e-brake and it wasn't engaged.
  • Coolant brown to black color
  • Cruise Control not working
  • Electric mirrors not working
  • 3/4 quart low Trans Fluid though color looked ok
  • Engine Oil freshly changed and full the to mark; wondering if this was just good service or a cover up of a coolant/oil mix issue
  • Engine Oil leak around engine oil drain pan
  • Tranny drain pan bone dry, but dented inward
  • A/C seemed to cut off and then back on while on interstate just 1 time, was at max a/c on 90 degree day; I wonder if it did this when I accelerated briskly??
Pros:
  • Motorized lift in back for handicapped electric chair (need this for my mom badly; main reason I was looking at this van)
  • Impressed with the wear physically inside and outside for its age. 135k miles - I'd rank it between good and excellent shape
  • Drove wonderful except for slight gear slipping on interstate, but I know how touchy these trannies are in the Windstars and the fluid has to be perfectly filled up to not have this
  • A/C worked great considering how hot it was outside, except for that brief cut off during interstate run
  • Electric adjustable gas/brake pedal
  • Kenwood head unit
  • Good tires
  • Handled and drove well. Easy to drive. Smooth turning wheel.
  • All front/rear a/c vents responded to controls in front and back
  • Turn signals worked
  • Wipers worked
  • Interior almost flawless
As a lot of you veterans on here already know, I have had a 95 Windstar and nearly rebuilt it entirely since i've owned it. I know there's a recall on the brake switch something or other which affects the cruise control, but I wonder if cruise wasn't working due to the low brake fluid???
Thanks again to all you wonderful peoples!!!
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
searcherrr is offline   Reply With Quote
Old 06-12-2013, 03:49 AM   #2
Windstartled
Re: Looking at 2002 Windstar LX to buy
What do you mean by "tranny drain pan bone dry", you removed it and nothing came out?
Also what is the asking price and would the seller agree to an inspection (on your dime)?
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal
2008 F150 FX4 5.4L V8 - Wintermobile
2000 Windstar SE 3.8L V6 - Beast of burden
1995 BMW 540i 4.0L V8 - Weirdest car ever owned
Windstartled is offline   Reply With Quote
The Following User Says Thank You to Windstartled For This Useful Post:
searcherrr (06-13-2013)
Old 06-12-2013, 07:34 AM   #3
12Ounce
I would be suspicious of a coolant-to-crankcase transfer leakage. Not the end of the world, but I would plan on an engine overhaul soon.
If the car looks good, is free of rust and dents ... and is priced right, I would be interested. But then, I almost look forward to rebuilding an engine, just so I know its good to go.
12Ounce is offline   Reply With Quote
The Following User Says Thank You to 12Ounce For This Useful Post:
Old 06-12-2013, 07:59 AM   #4
northern piper
northern piper's Avatar
If it were me, I'd be giving a deposit and saying that you'll buy the van on the condition that an oil sample sent to Blackstone labs comes back with an acceptable report. Blackstone does quick turn around for people in your situation and I'd expect you'd have a result in a day or 2. I'd also be topping up the trans fluid myself with mercon V just to see if that slip is because of fluid level or damage. At 135k, it's sort of at the "beginning of the end" from the trans point of view. You could also get the vin and go to Ford and see if/what's been done on the van. Brake pressure switch should have I believe. What are they asking just out of curiosity?
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
northern piper is offline   Reply With Quote
The Following User Says Thank You to northern piper For This Useful Post:
Old 06-12-2013, 08:54 PM   #5
scubacat
Here are my thoughts on the "cons" (which is probably what you most want info on, anyway). Our 2002 SEL has 138K miles and the transmission has never had a single problem whatsoever. It shifts just like it's brand new.
- Could just be pad wear
**** SCDS is leaking. See "cruise control not working" below. ****
- I'll bet you a dinner at Bones it's the lower intake gasket. Not a terrible job but not fun either.
- Brake pressure switch (SCDS) not replaced at recall. Mine wasn't either; had to buy it myself. Brake fluid leaks and shorts out the switch. $18 and you'll have cruise control again.
- probably a fuse or something
- hard one to judge; sometimes it seems that way when it's fine. The dipstick isn't a perfect measurement. If it shifts properly, I would leave it and disregard.
- you never know on that one. Again, lower intake gasket is probably blown
- rear main seal. Mine does the same. It never leaks enough to actually drip on the ground though. I've ignored it for a few years now and it hasn't been a problem
- How much dented? Mine is a little like that from trying to lift the engine that extra 1/4" to replace the tranny mount. It hasn't been a problem for going on 2 years now. If you ever pull the pan, you can bang it back out.
- Hard to tell. Could be a leak/bad freon charge. Maybe they threw half a can in from advance auto to make it work while you test drove and it'll all leak out shortly thereafter. A/C is really tough to diagnose though. It could also just be a bad cycling switch which is a quick, easy, & cheap repair.
scubacat is offline   Reply With Quote
The Following User Says Thank You to scubacat For This Useful Post:
Old 06-12-2013, 08:55 PM   #6
scubacat
Almost forgot! If cruise control is not working because the brake pressure switch wasn't replaced, that's the issue with brake fluid -- it's leaking there. Replace the switch and you'll both stop the leak and get the cruise control back. I'll update the post above.
Old 06-13-2013, 02:11 AM   #7
searcherrr
Question Re: Looking at 2002 Windstar LX to buy
I checked under the brake fluid reservoir while I was there and I didn't see any wet brake fluid on the wiring of the brake pressure switch... which is directly the only one coming out of the bottom of the master cylinder right?
Old 06-13-2013, 02:13 AM   #8
searcherrr
The bottom of the tranny pan was bone dry, yet there was a pretty wide area dent in the pan in the center... inward maybe 1/2" if I was guessing.
They wanted $3900 for the van, but I am offering $3500 and they bit on it. Supposed to pay tomorrow.
So, the 2002's are known for lower intake gasket problems??? even after all that mess with the intake gasket's in the early Windstar years???
Old 06-13-2013, 02:15 AM   #9
searcherrr
Yeah, I feel the same actually.. then you know where you stand with your vehicle once the engine is redone, but I need this to be reliable for my cripple mother. It seems to have been driven very softly. Its really in good looking shape visually.
Lots of coolant to crankcase leakage on the 2002's ?? REALLY? I'm just having a hard time believing this after Windstar's history.
Old 06-13-2013, 08:52 AM   #10
12Ounce
I would guess all the 3.8's had this "opportunity" to cross fluids from the crankcase to the cooling system. Its just the nature of the beast ... the tricky lower intake manifold gasket (already mentioned above) ... and the more-tricky front engine cover gasket. It all has to do with having a chain drive the camshafts ... once that design decision is made; where does the water pump go. ?? On later engines, Ford moved the water pump to the rear of the engine ... that eliminated the need for coolant to be ported through the chain drive area, back and forth.
The gaskets may be installed perfectly, or they may-not be. Usually the leaks are small and you will never "see" coolant in the oil,.... but the coolant will get an oily stain on top. Is this bad? Yes, because just a little coolant in the crankcase will cause severe wear on metal parts. As suggested, only a lab test will prove the gaskets are doing their job. (I have a gasket job facing me ... not looking forward to it!)
Old 06-13-2013, 08:59 AM   #11
northern piper
so congrats on the buy overall! These vans, despite a few annoyances, are pretty good I'd suggest. So if the oil is quite new, I'd run the van for 3000 and then send the sample to Blackstone. New oil really won't show much and all Blackstone will do is ask you to repeat the sample. With some mileage on the oil it'll show much more about fluid contamination, metal breakdown etc.Of note is that Blackstone also will analyze trans fluid.I sent them a sample at my last trans fluid change and got some good info back.
2000 windstar 3.8
Muskoka Canada
Old 06-13-2013, 09:19 AM   #12
phil-l
Regarding power mirrors:
It's almost certainly the "joystick" switch on the driver's door panel; my '00 had this problem.
The switch can be removed and disassembled pretty easily. The switch is made up of a set of layers; the joystick pushes sets of contacts onto to an underlying conductive layer. This creates the connections that run the mirror.
The problem is that underlying conductive layer: It's noted for building up a layer of oxidation that keeps it from completing connections. I was able to disassemble my switch, clean the contacts - and add a light layer of dielectric grease to prevent this problem in the future. My mirrors have been working fine for years since this repair.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
phil-l is offline   Reply With Quote
Old 06-14-2013, 01:32 AM   #13
searcherrr
Thanks. I bought it today.
Will Blackstone analyze coolant too or would it just make sense to only analyze the engine oil?
Old 06-14-2013, 01:33 AM   #14
searcherrr
Thanks for reminding me about "what moves is usually the problem". I had the same issue in my 95 Windstar with the rear windows and a new switch did the trick just fine.
Old 06-14-2013, 07:53 AM   #15
northern piper
I don't know if they do antifreeze or not; I've never seen that advertised on their site. They do analyze trans fluid so if it were me, I'd be sending a sample of the oil once it's got some mileage on it and the trans fluid as well. It'll cost ~$40 for the samples but will be money well spent IMO. If there's contamination between the coolant and oil the oil sample will show that so I'd be betting you wouldn't need a coolant sample evaluated honestly..
One thing I've always wondered is how my sample compares to others. I'd certainly share what I have for past oil change analyses if you'd be interested.
2000 windstar 3.8
Muskoka Canada
