Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 04-12-2010, 10:03 PM   #1
gta333
2000 s-10 leaking transmission fluid
My 2000 s-10 2 wheel drive truck has began to leak tranny fluid at a pretty good rate. We have 1000 of chuck holes this year in the streets. I trying to get a exact location on the leak. has anybody else had problems with them leaking. Im hoping its just the gasket and I will replace the filter and gasket. anyone else have any ideas Thanks for your time Gary
gta333 is offline   Reply With Quote
Old 04-13-2010, 09:43 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 2000 s-10 leaking transmission fluid
I am sure other people have had that problem.
But it is hard to match other peoples problenm with yours.
Most times same problem is caused by different things.
Most transmissions's have a hard rubber reusable pan gasket.
If not broke or someone has pitched it.
Always use it instead of cheap gasket that comes with a filter kit.
First thing you shoul do is find leak.
Clean off old leakage and fill up with fluid and drive then look for leaks.
Post back where it is leaking.
MT
