96 A4 2.8 headlights
HI everyone,
I have a 96 A4 and the head lamps would intermittently stop working. More specifically the low beams, high beams, and foglamps all were inoperative flash to pass however did work. I diagnosed it as a headlamp switch issue. I installed the new switch and now I have low beams and fog lamps but no high beams or flash to pass. I was able to supply battery voltage to the high beam circuit at the switch connector and light up the high beam bulbs so I think I have another bad switch. Any other ideas would be appreciated. |
Re: 96 A4 2.8 headlights
Check the wiring too. Maybe it is happening due to some cut.
Audi Q7 2008 Audi Performance Chip |
Sounds like your ground wire might be lose, try re-attaching it.
nevermind..
![]() ![]() Past Z Car Crew[The Enemy Of Your Enemy is Your Friend] >>Keep Your Friends close : But Keep Your Enemies Even Closer << Last edited by ExTrEmEDrIfT; 12-28-2009 at 02:44 PM. Reason: old post |
