Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 06-28-2015, 02:06 AM
searcherrr searcherrr is offline
Send a message via AIM to searcherrr Send a message via MSN to searcherrr Send a message via Yahoo to searcherrr
Question Air Bag Light on DASH and fuse blown
What would cause the air bag fuse to blow as soon as I turn on the ignition?
Have tried replacing the fuse and this happens (fuse blows out) each time.
95 3.8L... nearly fully rebuilt.
1995 3.0L 3000GT NA FWD ATX - ProwlerGT on 3si.org
1995 3.8L Ford Windstar GL
"I drive the newest 1995 Ford Windstar anywhere..... when its not broken."
Old 06-30-2015, 10:54 AM
tomj76 tomj76 is offline
Re: Air Bag Light on DASH and fuse blown
Obviously a blown fuse comes from an excessive current condition. This could be frayed wire insulation allowing the powered wire to touch the body, or it could be the airbag assembly itself. One way to start is by disconnecting electrical connection at the air bag. That will tell you if the problem is in the wiring or the airbag assembly.
Old 06-30-2015, 11:30 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
there is also a airbag module that could be bad, usually mounted under dash or inside center console if it has one. wiring to airbag is usually wrapped in yellow insulation covering
