Old 04-19-2010, 04:49 PM   #1
dclegg61
98 rodeo- timing WAY advanced by PCM
timing on my rodeo seems way to advanced. Spec 12 degrees, reads 19-20 degrees at idle and up to 45-50 degrees while accelerating.
Looking at data from each sensor on my OBD2 scanner. But I need a resource to know what each should be, so I can pinpoint the problem. Any suggestions?
dclegg61 is offline   Reply With Quote
Old 04-19-2010, 06:48 PM   #2
dclegg61
Re: 98 rodeo- timing WAY advanced by PCM
forgot to say engine has to spin for several seconds before it starts
Old 04-19-2010, 07:13 PM   #3
Cat Fuzz
I'd begin by looking for vacuum leaks. When unmetered air gets into the engine, the PCM compensates for the lean condition by increasing fuel which increases the engine speed which advances the timing.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Cat Fuzz is offline   Reply With Quote
Old 04-20-2010, 02:15 PM   #4
dclegg61
I searched the engine over and couldn't find any vacuum leaks.
One other thing, that I think is just coincidental, This started a few days after I replaced the timing belt, tensioner, and pulleys. But that thing was so tight that I almost couldn't get the belt on, so I don't THINK it could have slipped.
Old 04-20-2010, 03:08 PM   #5
Cat Fuzz
Well, I tend to think that if you don't have a CEL you everything should be ok. That little bit of advance at idle isn't a concern and the timing always advances when accelerating and higher RPM's. I hooked up my scanner and I'm also idling at 19 degrees advanced and 800 rpm's.
I'm thinking it's nothing to worry about. If your timing belt jumped even one tooth, it would run rough and totally crappy.
Old 04-20-2010, 09:49 PM   #6
dclegg61
Thanks Cat Fuzz!!! the timing must b ok. I was pretty sure teh belt was still ok
Thanks again.!!!!!
