Go Back   Automotive Forums .com Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-03-2010, 12:42 PM   #1
pieps57
What exactly is wrong?....
I have a 95 explorer and lately it wont start. When I turn the key forward the fuel pump wont kick in. If I have someone turn the key forward while i tap the gas tank it while kick on. Once it starts in runs flawlessy.
So is it a bad connection?Bad fuel pump?something else?????
Thanks
pieps57 is offline   Reply With Quote
Old 02-03-2010, 02:24 PM   #2
shorod
SHO No Mo
shorod's Avatar
Re: What exactly is wrong?....
Pretty typical symptoms of a bad fuel pump. Untimately it's a bad connection, but the connection is usually the worn brushes inside the pump motor, similar to tapping on a worn out starter motor to get it to work for another time or two.
-Rod
Old 02-03-2010, 09:50 PM   #3
pieps57
OK thank you.
What specifics do i need to know when buying a fuel pump? Cuz werent exploreres made in like canada US and mexico in 95?
Its a 95 explorer sport 2 door 4.0
I dont wanna get the wrong one.
Thanks again
Old 02-03-2010, 11:57 PM   #4
shorod
SHO No Mo
shorod's Avatar
I cannot answer that, but if you have the VIN number for your vehicle you should be able to get the correct pump from a parts store. Or you could just go with the universal pump and retrofit it to your existing assembly. The universal versions don't save you much money though and tend to be noisier than an OEM replacement.
-Rod
Old 02-04-2010, 06:50 PM   #5
way2old
TOKEN HILLBILLY
way2old's Avatar
Go to www.motorcraft.com and enter the VIN and search for fuel pump. It will give you the Motorcraft part number and than you can cross it over to other brands if you want.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
way2old is offline   Reply With Quote
