Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 01-23-2010, 04:31 PM   #1
Skyemustang97
Exclamation need help removing the starter
trying to remove teh starter solenoid from my car.. thinking.. hopeing its the problem i have.. i jus had a new engine put into my car.. but however maybe a day or so after everything was completed.. after my car was running and all with the new engine in it.. i had problems with my power supply.. i will try and explain the best i can.. when i turn the key in the ignition i get no response. no click noise from the stater no lights no nothing... but however when i have somebdy jump me once the battery cables .. my car starts up fine runs great.. but once i shut my car off.. im back to geting nothing.. so once its off it stays off.. untill i get another person to jump me.. ive asked around an people have been telling me to start with the solenoid.. i guess my little problem is that the location of the starter is in a bad place.. i jus have no room to do anything.. if anyb dy has any experience installing and removeing starters on mustangs.. any advise would be truley greatful.. thank youi
Skyemustang97 is offline   Reply With Quote
Old 01-23-2010, 09:01 PM   #2
Davescort97
Escort guy
Re: need help removing the starter
Welcome to AF!
It sounds like the battery is discharged or the terminals on the battery are dirty or loose. Check the voltage with a DVOM. It should be 12.6 volts or more. If the battery is fully charged and the connections are tight and clean, then you may have a bad ground cable. Measure the resistance from the negative battery post to the engine block. There should be little or no resistance. If the resistance is more than that you need to clean the negative ground cable.
If you want to change the starter you will need a ratchet with an extension to get the top starter bolt. The bottom bolts are easy to get to. Before pulling the starter disconnect the negative ground cable from the battery.
Davescort97 is offline   Reply With Quote
Old 01-24-2010, 03:33 PM   #3
Blue)(Fusion
Blue)(Fusion's Avatar
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
I'd suspect a weak alternator or a wiring problem preventing the battery from charging. Frayed wires or lose connections can cause this. You can also take your car to an auto parts store where they can test the alternator and battery in your car. It might help identify the problem.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Blue)(Fusion is offline   Reply With Quote
Old 01-24-2010, 07:53 PM   #4
mechhound
It always helps to give the year, and a lot of times what engine you got. A lot of times the terms solenoid and relay are interchanged.
It's not the solenoid on top of your starter, beings it starts with a jump. It wouldn't be the relay either. I would start by making sure you have a good and also well charged battery, and the battery cables are in good condition and clean and tight.
mechhound is offline   Reply With Quote
Old 01-24-2010, 08:49 PM   #5
rhandwor
Look and if you spilled anti freeze on the ground or positive connections clean with contact cleaner.
rhandwor is offline   Reply With Quote
