Go Back   Automotive Forums Car Chat > Oldsmobile > Intrigue
Old 03-10-2010, 03:56 PM
sparcx sparcx is offline
Replacing PCV Valve for 3.5L Intrigue?
Anyone know if this is difficult and how to to go about doing it? My car is at 100k miles and I thought it might be worth doing from what i've read.
I'm pretty handy, but most of my experience with car maintenance is pretty limited to the more common stuff like filters, maf sensor, battery, etc.
Old 03-10-2010, 04:10 PM
Tobey Tobey is offline
Re: Replacing PCV Valve for 3.5L Intrigue?
You could do it in your sleep then. Pull the plastic engine cover off (two plastic nuts on top), you'll see the PCV next to the right engine cover stud. Just pull it out of the engine, pull the hose off of it, and replace it with the new one. Done.
Old 03-11-2010, 04:24 PM
well that was amusing. Probably the easiest and cheapest maintenance i've ever done on this car.
The old AC delco seemed to be in decent shape as it still rattled around. I swapped it for a new Purolator for $3.
I attached a picture of where it is. Exactly as Tobey stated. Right next to that stud.
thanks tobey
Old 03-13-2010, 05:20 PM
krivasauto krivasauto is offline
Banned
When I changed mine out the elbow was old and cracked. Autozone didnt have one for the Intrigue, but I bought one for a Chrysler that did the trick.
Old 03-13-2010, 07:37 PM
was it pretty noticeably broken?
the elbow on mine seemed to be in decent shape as you can see from the picture above. I didn't really inspect it all too well though.
Old 03-14-2010, 08:23 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
I've honestly NEVER seen a PCV valve that I would consider worn out. It usually just gets gunked up which causes it to stick and not work properly. Clean it out with some carb/brake/throttlebody cleaner and it's as good as new. I did this at every oil change when we had our Intrigue (3.5L) because the PCV valve was always gunked up with a murky oil/moisture blend (which is especially common with any engine in a car that performs alot of short trips). I believe it was a huge contributor to the excessive oil consumption we experienced. It easily went through 2 quarts between 4,000 mile interval changes. (but according to GM, 1 quart every 2000 miles is normal LOL). I'm confident in saying that anyone that removes the MAP sensor from the plenum on the 3.5L will notice an oily buildup on the nipple.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 03-14-2010, 10:15 AM
Banned
Yeah, the rubber will be hard and will crack. Makes sense to pick up spare connector and save a repeat visit.
