Go Back   Automotive Forums Car Chat > Toyota > Cressida
Old 08-07-2009, 01:29 PM
nokel25 nokel25 is offline
Unhappy 1983 Cressida Help
I have a 83 Cressida Sedan that's my pride and joy. I've been trying to restore her to her past beauty and I've hit a snag. The air intake connector has a hole in it. It's been patched up before, but I don't think it can be patched this time. I've tried every parts store I could find and tried to order it from toyota, but the part has been discontinued. Toyota told me to try ebay. Does anbody know a website that carries old toyota parts(besides ebay-no luck-2 months) or some adhesive that will seal it up. I'll try to post pics of the old patch later today. I've been searching for months, but no luck. Thanks in advance.
Old 08-07-2009, 06:55 PM
Franco2112 Franco2112 is offline
Re: 1983 Cressida Help
You could try a scrap yard. You might have to either make the part your self or buy a cold air intake set up. I know you're probably trying to keep it stock, it just may not be possible.
Post a picture of the part if you could.
Old 08-10-2009, 12:22 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
You could try some Duro plastic welder epoxy to fill the hole. It sets fairly fast (15 minutes) and stinks like hell, but it does a good job of rebuilding plastic pieces. After it cures, you can machine it, sand it, paint it, etc.
You could also purchase a plastic welder, which is basically a cross between a hot glue gun and a soldering iron. The tip is heated and pressed against the part to be repaired, and a hole through the tip allows you to insert the welding stick of plastic to melt and flow into the repair. As long as the weld site is not at a stress concentration (i.e. a support bracket tab), the weld should hold. Various weld sticks are available to match the material being repaired.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-04-2009, 07:47 PM
rhandwor rhandwor is offline
http://www.dskatools.com/ Click on specialty tools it will be around page six. This is large diameter vacuum tubing with a swag lock. They have a decent tool price if you need some items. Grey pneumatic makes 12 point impacts 30mm and 32mm. They also make 10mm,12mm,14mm deep 12 point impacts for a good price. $30 or $40 minimum order.
