Go Back   Automotive Forums .com Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 11-11-2002, 09:04 PM   #1
IVINS812
wet engine
my bugs engine doesn't run to good when soaked (it raines a lot in southeast louisiana). Does any of you know where to get a guard, that can be attached to the motor cover that keeps out water but will let it breath ???
IVINS812 is offline   Reply With Quote
Old 05-28-2003, 09:15 PM   #2
HillbilySailor
HillbilySailor's Avatar
Send a message via AIM to HillbilySailor Send a message via Yahoo to HillbilySailor
Old or new style Bug????
HillbilySailor is offline   Reply With Quote
Old 07-08-2003, 11:34 PM   #3
harrybeaver
Banned
easy solution
Put a sock in the intake, that should solve all of your water problems and should filter out all of dirt, and if that dosent work take a hose and put a bunch of water in your oil pan. That way you dont have to worry about water getting in the engine because theres already enough there to solve the problem.
harrybeaver is offline   Reply With Quote
Old 07-16-2003, 10:53 PM   #4
plebsmacker
dont listen to harrybeaver
sounds like an 8 year old to me , all of his advice is full of crap , just some idiot trying to make trouble for others that may not know what they are doing
k
plebsmacker is offline   Reply With Quote
Old 10-21-2009, 10:14 AM   #5
mhalliar
Re: wet engine
I have the SAME problem when it rains.... and it's been a rainy summer and fall.... everytime it rains the car won't start and I have to feather the gas just to get it to run. WHEN it finally is running, it's really rough and blowing smoke all over the neighborhood. I THINK it might have something to do with the spark plugs, because if they're wet at all, it would misfire... have you ever had them changed? Mine look pretty old as well, but I don't have the money to take it in and get them replaced because guaranteed it's going to be a $500 job just to replace the spark plugs.... it looks like you have to take off the fuel injector manifold on the top of the engine. I took the plastic cover off months ago. POS... I hate these cars.. they've been nothing but trouble since the very beginning!!
mhalliar is offline   Reply With Quote
Old 10-22-2009, 11:04 AM   #6
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
Re: wet engine
/\ you probably have a cracked coilpack or arcing spark plug wires. The spark plus are easy to replace they do not require removal of the intake manifold. You need a swivel spark plug socket to get the plugs out.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
veedubmechanic is offline   Reply With Quote
