1998 Blazer Oil Pressure Gauge
Just bought a 1998 Blazer LS w/83K on it.After warm up & on the highway,what is the normal reading the oil pressure gauge should be at?
Thanx! |
AF -Advisor
![]() Join Date: Sep 2003
Re: 1998 Blazer Oil Pressure Gauge
What speed?
1995 Factory Blazer Service Manual for sale, PM if interested. |
At 55 mph.
When it's at idle it's around 40~42 |
AF -Advisor
between 1/2 and 3/4
my 95 while driving at any speed, as long as im on the gas, it will be a notch above the middle(40) when stopped and idle, goes below half. 1/3 id say. that too low?
#6 | ||
AF -Advisor
Re: Re: 1998 Blazer Oil Pressure Gauge
#7 | |
Problem?
![]() Join Date: Dec 2004
The norm would be about 30 - 40 at idle and 45 - 60 while driving.
Personally, I wouldn't run it this low, but the minimum while hot is: 1000 rpm..............6 psi 2000 rpm............18 psi 3000 rpm............24 psi |
#8 | |
I have a 98 blazer. I was driving at about 85 wen my check engine soon light came on. There is no oil leak. The temperature stays normal. But i have no idea why the light came on.
#9 | |
The RustBuster
![]() Join Date: Feb 2006
Any other symptoms other than the check engine light? I presume you have low to no oil pressure if you're posting to this old thread. Check your oil level. If the stick is dry, you're burning oil. Then get a scanner and read the trouble code.
The other common problem is a loose gas cap. Check the o-ring for good seal. Hope this helps!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
