Go Back   Automotive Forums .com Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 06-30-2009, 08:49 AM   #1
00trooper
2000 Trooper 3.5 v6 Check Trans Blinking
Hello,
I had my transmission replaced about 2 months, 3000 miles ago. I was getting onto an on ramp recently and hit a nasty bump in the road and now the check trans light is blinking. I got underneath and looked and didn't notice any visible damage or leaks. Does anyone have an idea what can cause this? Did something get knocked loose?
Thanks in advance!
00trooper is offline   Reply With Quote
Old 07-03-2009, 03:51 PM   #2
00trooper
Re: 2000 Trooper 3.5 v6 Check Trans Blinking
Nobody has seen this???
Old 09-08-2009, 07:52 AM   #3
kplusten
It is most likely the transmission position switch that sits next to the transmission. Common problem usually discovered when hitting a bump. Easy to change, not expensive.
kplusten is offline   Reply With Quote
Old 09-08-2009, 01:47 PM   #4
fourwd1
AF -Advisor
fourwd1's Avatar
I had that switch (the range select/mode select sw) go bad on my 00 Trooper and the symptoms I got were erratic shifting and incorrect indications on the gear display, although it can also exhibit as hard shifting and other problems, but no Check Trans light (but don't rule it out).
Since you recently had the trans replaced, it's possible one of the electrical connectors was not mated properly and is not making proper contact after the bump. You may want to get underneath and check, they can be difficult to access, which is another reason one may not have been connected properly.
But first I'd get the CEL codes checked even if you do not have the CEL lit.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
fourwd1 is offline   Reply With Quote
