Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 10-07-2006, 03:35 PM
coleld coleld is offline
1988 Wrangler won't idle
I have an 88 Wrangler 5 speed , 6cyl with carburator . 94000 miles That won't hold an Idle. I can drive it down the road just fine but as soon as I take my foot of the gas pedal it stalls and will start right back up. Any help would be appreciated.
Old 10-08-2006, 02:43 PM
SVTballa SVTballa is offline
Re: 1988 Wrangler won't idle
have you checked your idle. maybe its set to low either that or your choke is broke and doesnt work. does it idle on its own at start up?
Old 10-08-2006, 03:24 PM
Thanks for your reply... No it won't idle on a start, your right almost like the choke doesn't work. But it won't idle when the temp is up either. I can drive it and it will run pretty good but as soon as I take my foot off the pedal she dies. Like the gas stops feeding the carb???
Old 10-12-2006, 10:17 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
My first thought is that it would be the idle adjustment screw on the carburetor. It keeps the butterfly in the carb from closing all the way when your foot is off the gas. You should be able to locate it on the side of the carb where the linkage is, and make an adjustment to keep it running @ idle.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-13-2006, 11:09 PM
ANOTHERLURKER ANOTHERLURKER is offline
check for loose, cracked or missing vacuum lines going to the carb. i beleive ther eis one on the left side, driver side that will kill the idle if it is not attached
Old 10-17-2006, 12:34 AM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
I would check for a vacuum leak first. Make sure that the MAP sensor has a vacuum too.
Also try to reset your computer by removing the postive lead of the battery and turn the ignition key to start and off (three time minimum) then re-connect the battery. Start and drive for a mile
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
Old 10-19-2006, 07:39 AM
Good points on the vacuum; is it idling now?
Old 10-23-2006, 06:28 PM
ya i should check my vacuum lines and stuff. i just took the idle screw out and so now at cold starts i have to give it gas myself or else it will turn off but once its warmed up it runs at idle. I have another problem that yall might be able to help me with sometimes when i turn my car off it has a really hard turn off like my whole engine shakes and goes all crazy and sometimes it wont even turn off it will just keep shaking and stuff real hard and the car will turn right back on real quick if i turn the ignition...what is wrong?
Old 10-24-2006, 07:44 AM
Sounds like it needs a tune up pretty bad.....
Old 10-30-2006, 08:51 PM
Quy Le Quy Le is offline
Send a message via AIM to Quy Le
evne with a tune up it would do that, thats cuase by many reasons really, Mainly carb operater vehicles, because the engine runs so hot that even spark cutoff on the engine it still fires gasoline, thats called Dieseling, happens alot of old motorcycles too, i ebt ya it happens alot when its really warm. If your fuel injected thats a different story, fel is 100% cutoff on those. but for carbuerated the manifolds going to have some gas in it, a tune it would help, carbon buildup can make the situation worst. i can go on for days.... i had a 1987 dodge omni like that...
Old 10-31-2006, 10:33 PM
bdiamond69 bdiamond69 is offline
88 wrangler are known for crappy carbs. i know i had the same problem till i went completely through my jeep. at a minimum you need to rebuild the carb.
a better thing to do would be buy a new one
89 jeep wrangler with a 360 amc v8 40 over
msd ignition system from box to wires
edelbrock performer intake, cam
holly fuel inj
k&n air filter
tubro 400 trany with shift kit
dana 44 axles 4.56 gears
all 4 wheel power disc brakes
6 1/2 inchs of suspension lift
rci racing seats
simpson 5 point harness
griffin aluminum radiator
REAL JEEPS ARE BUILT NOT BOUGHT
LIFT IT --- FAT CHICKS CAN'T JUMP
Old 11-01-2006, 07:54 PM
1987-1990 wrangler with a 2.5 were throttle body fuel injected.....
Old 11-02-2006, 08:46 PM
what 6cyl were 2.5 lt and he said it has a carb. you need to check your sources.
holly fuel inj
k&n air filter
rci racing seats
Old 11-04-2006, 12:06 AM
Perhaps i read it wrong, i thought it was a 4banger alright dude.
Old 11-09-2006, 08:54 PM
YJ Guy YJ Guy is offline
Carter carbs are a little troublesome but if you rebuild it and set it up right it should be ok. Has anyone heard of the " nutter bypass " it rewires the ignition and bypasses the computer. My 88 YJ ran like crap most of the time, it would run ok but not idle until I did this bypass. Now it runs great and here in Ontario, Canada we have emission testing and my Jeep just passed easily.
