Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Performance
Performance Anything you ever wanted to know about boosting the performance of your Cavalier.
Old 07-26-2009, 12:38 AM   #1
E. Frank
engine swapping
ok so i'm new to this shit. anyways, replacing the engine in my 99 sunfire gt 2.4 l twin cam auto is on my list. what are some good brands? i've noticed ecotec on the forums a lot, but is that it? and is there anything that might be designed for my car that i wouldn't have to make custom parts for? i just don't have the access to most of the tools or materials needed for that sorta shit.
E. Frank is offline   Reply With Quote
Old 07-27-2009, 05:18 PM   #2
J-Ri
J-Ri's Avatar
Re: engine swapping
The Ecotec is, IMO, the only worthwhile option. As much work as that is, and since you say you don't have the tools, I'd suggest you just build your engine for some more power and throw a turbo/super charger on it.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
J-Ri is offline   Reply With Quote
Old 07-27-2009, 10:53 PM   #3
E. Frank
Re: engine swapping
since the ecotec is a 2.2 l engine and what i've got now is the 2.4 l, am i gonna lose power and performance and all that if i switch to the ecotec?
Old 07-31-2009, 10:49 PM   #4
J-Ri
J-Ri's Avatar
Re: engine swapping
Technically you would have less power... The Ecotec has 5 less HP but is soooo much lighter due to the aluminum block that the lower weight gives you better performance (and much better high speed cornering. There is also much more aftermarket performance stuff around for the Ecotec since the quad4 is no longer in production.
Old 08-01-2009, 10:40 AM   #5
E. Frank
Re: engine swapping
aight thanks man. where should i go to get one? i did an internet search and didn't appear to find any available for sale, but maybe i'm just bein a dumb ass
Old 08-04-2009, 04:12 PM   #6
J-Ri
J-Ri's Avatar
Re: engine swapping
www.car-part.com had 33 pages of results.
I would personally get one from a local salvage yard, but it's up to you.
Old 08-07-2009, 07:37 PM   #7
Jmrec100
Jmrec100's Avatar
Re: engine swapping
There is a good place in NY to get engines. Used ones. They are on ebay. Respectable, courteous, honest and reputable. I bought a used 2.2L engine and Trans for my 1999. So far so good. I will find out next weekend when I finish the installation.
Jmrec100 is offline   Reply With Quote
Tags
engine , replacement , swap
