Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-29-2009, 11:26 PM   #1
tnbgaskill
1997 2.0 into a 1996 motor swap
I recently pulled a motor and tranny out of a 97 put it in a 96, changed coil pack and crankshaft pos wiring. purrs like a kitten but when you stomp the gas it acts like it wants to flood out or sounds like the rev limiter have pulled and cleaned tb checked the timing pretty much checked every sensor on the thing about to give up. HELP
tnbgaskill is offline   Reply With Quote
Old 07-30-2009, 06:21 AM   #2
RahX
Re: 1997 2.0 into a 1996 motor swap
You're sure the timing belt is in time.
RahX is offline   Reply With Quote
Old 07-30-2009, 09:50 AM   #3
tnbgaskill
yep did by the book checked and rechecked has the right belt marks line up perfectly i am stumped
Old 07-30-2009, 09:01 PM   #4
RahX
You say you messed with the crank sensor wiring, what did you do? Did you have to change from a flat pin connector to the round pin or??
Old 07-31-2009, 12:38 AM   #5
tnbgaskill
exactly what you said had to switch connectors
Old 07-31-2009, 07:16 PM   #6
tnbgaskill
i was playing around with it today and when i control air flow on the throttle body runs perfect dont spit and sputter, when i bought this car he had a k=n filter on it is it possible he unhooked something or screwed up the mass air sensor by doing this?
Old 08-05-2009, 11:04 AM   #7
HPNOTIQracing
there is no mass air flow sensor. i would try replacing the iac and/or the tps
iac= idle air control valve
tps= throttle postion sensor
are you guessing its getting to much fuel? can you smell fuel? mabey not enough fuel. filter, pump?
HPNOTIQracing is offline   Reply With Quote
Old 08-05-2009, 11:07 AM   #8
tnbgaskill
changed both no difference
Old 08-05-2009, 11:09 AM   #9
HPNOTIQracing
mabey a fuel issue then. did you check your fuel pressure
Old 08-05-2009, 11:09 AM   #10
tnbgaskill
dunno when i press in on the release valve on fuel rail it doesnt spray out gas just trickles out is this normal
Old 08-05-2009, 11:10 AM   #11
tnbgaskill
i need to get ahold of a pressure tester or is there some hillbilly way to check pressure?
Old 08-05-2009, 11:13 AM   #12
HPNOTIQracing
is this with the key in the run position?
Old 08-05-2009, 11:20 AM   #13
tnbgaskill
key on , key off, running does the same thing throughout i would think it would spray out it does on my jeep and durango dont really want to drop 299 on fuel pump/ pressure regulator
Old 08-05-2009, 01:03 PM   #14
HPNOTIQracing
with it running you should deffinatly get some pressure. i would start with the fuel filter. when did you change that last? then pump. probly not regulator
Old 08-08-2009, 07:09 PM   #15
tnbgaskill
Thanks for the residual guessing but i figured it out was the plug in for the tps wires inside the plug in were wore out. Until next time stay cool.
