Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-29-2009, 04:27 AM
workinmanfred workinmanfred is offline
How do I get wider tires?
My 95 CV is in need of tires. I would like to maybe try a wider tire. Currently it has 215/70-15's on it. How do I buy a wider tire? Do I go up to a 225/70-15 or does it go up to 215/80-15's. Is that a stupid question? I know the 15 is the rim size..what are the other numbers?...Will going up one size affect mileage that much? or handling?
Thanks for the info
Old 07-29-2009, 07:11 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: How do I get wider tires?
Changing the tire size will cause the PCM to change shift points, fuel consumption, possible ABS problems. I do not think changing the size will gain you anything.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-30-2009, 07:49 AM
Stick462 Stick462 is offline
Here is a nice tool you can play with to find a wider tire that wont upset your speedo.You could switch to 225-60.15 for 1/2 inch wider or 225-60-16 for 1 inch wider.Read the information below this tool as you change tire sizes for speedo changes to see the different. Try this tool and judge for your self http://www.miata.net/garage/tirecalc.html
Old 07-30-2009, 09:39 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
for 225/60 R15..... the '225' is the tire carcass width (not tread width) in millimeters.
The '60' is the "aspect ratio" In this case, it means the tire height is 60% of the carcass width.
The 'R' means its a radial tire construction (and not a bias-ply).
