Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Silverado
Old 06-18-2009, 07:44 PM   #1
icefishingnut77
blower motor resistor
I bought a blower motor resistor for my 2001 chev silverado 1500 half ton due to the first 2 speeds not working. I bought it from checker auto. this was the one for my truck acording to there book. when i took out the old one the mounting plate was the same and the plug that goes into the blower is the same . the old one has a circuit board. the new one has actual resistors on it. my question is is that ok. is there different types for the truck. i put it in and it works but want to make sure its ok. i called checker and they said it should be ok.
thanks in advance
gs
icefishingnut77 is offline   Reply With Quote
Old 06-18-2009, 08:02 PM   #2
MagicRat
Nothing scares me anymore
MagicRat's Avatar
Re: blower motor resistor
Actual resistors is fine for your use, so long as the resistors mount inside the air duct, so they get good airflow. This is required to cool the resistors.
The resistor design is probably cheaper to produce, which is why they sell it.
If it ever stops working in the future, it's probably the thermal fuse that has let go, and not the entire resistor pack. The thermal fuse sits next to the resistors itself; new ones are usually available at Radio Shack.
MagicRat is offline   Reply With Quote
Old 06-18-2009, 09:19 PM   #3
icefishingnut77
yea there is like a ceramic white piece in the middle then a resistor on top of that and a couple of resistors on the bottom of it. is the ceramic peice the one your talking about? and yes it does mount into the duct for air flow i be;eive
thanks for the reply
gs
Old 06-24-2009, 03:05 PM   #4
fire24resque
fire24resque's Avatar
I had the same problem with my 2001... I purchased the first one from Advance Auto and he guaranteed it to be the right one and I got the one you said. I returned it figuring it wouldn't fit and I ordered the correct one from www.rockauto.com They have the one that you will actually find in your Silverado!!
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
fire24resque is offline   Reply With Quote
Old 06-27-2009, 08:01 AM   #5
FrankB43015
I replaced with one like you described too and have had no issues in 3 years. make sure you change your cabin air filter as well.
FrankB43015 is offline   Reply With Quote
Old 07-06-2009, 09:41 PM   #6
icefishingnut77
I did replace it with the one i bought works fine so far. Where is the cabin filter? Down where the reisistor is mounted? Didnt know there was one there
thanks
gs
Old 07-11-2009, 04:49 PM   #7
FrankB43015
thanks
gs
Right next to the resistor. You'll notice the fresh air.
