Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 06-27-2009, 10:05 PM
ello ello is offline
removing bezel?
Lol hello everyone.
I have the noobiest question ever. I have an old 96 Toyota corolla and I cannot find any help on removing the bezel to be able to remove the deck installed. I finally found 2 clips at the very top right of the bezel, but it doesn't seem to pop off using a flat screwdriver (not prying too hard as I dont want to break the flimsy plastic :P) Does anyone know how to get the bezel off here to remove the deck installed?
Here is pic I found of what the TOP PART of the bezel looks like:
Thank you very much,
-ello
Old 06-28-2009, 07:13 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: removing bezel?
check underneath, mine has two screws under the bottom. Also pull the clock out, there is often one under that.
Old 06-28-2009, 09:14 PM
Re: removing bezel?
I took out the two screws and still cant get that piece to budge. How did you remove the clock without removing this plastic piece?
Old 06-29-2009, 06:59 PM
Audio Guy
Re: removing bezel?
mine just pops out with a little pressure, but it's a honda - maybe it's different.
Perhaps you should ask this in the Toyota section, they would be a little more familiar with them than I would.
Old 06-29-2009, 09:10 PM
Re: removing bezel?
what part do you apply the pressure to, to get it to start to pop off.
Old 06-29-2009, 10:13 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: removing bezel?
I'm moving this to the Toyota forum for additional responses.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 06-30-2009, 05:26 AM
Audio Guy
Re: removing bezel?
my panel is angled and so the bottom of the clock has a flat spot that I can press against to pull it out. Try gently prying it out with a flat tip screwdriver.
