Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 06-20-2009, 06:38 PM   #1
Johnutone
2002 Mustang foglight
Hello,
I have a 2002 Ford Mustang and the fog lights stopped working. I find it unlikly that they both burned out at the same time. I checked the manual for the fuse location and it's not listed. It does mention a foglight relay in slot #1 of the power box. Everything else seams to be working.
Does anyone know if there is a fuse for the foglights? or should I have the relay checked at Trac auto?
Any help you can provide is appreciated.
Johnutone is offline   Reply With Quote
Old 06-20-2009, 10:50 PM   #2
Davescort97
Escort guy
Re: 2002 Mustang foglight
There should be a fuse along with the relay. I'd check all the fuses first. The relay is just that, it uses a low power switch to transfer a higher amperage to an accessory that uses too much power to be hooked directly to a switch.
Davescort97 is offline   Reply With Quote
Old 06-25-2009, 08:50 PM   #3
Johnutone
I wanted to post this so no one wastes his or her time doing what I did. I looked though fuses checked relays and they were fine. I did not check the bulbs assuming that it would not be possible for both to go at he same time.
I contacted the Ford parts department and was told to check the bulbs. After cussing under my breath because I felt that they brushed me off I finally crawled under the car to check the bulbs.
The fist bulb was blown, almost no glass left - the second was the same.
I replaced both bulbs and they are working - guess the parts guy knew what he was talking about.
Try the simple solution first. I hope this helps someone out there.
