Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Old 12-06-2004, 10:25 PM   #1
Jamesmc5
68 mustang dies on hard acceleration
This is one of multiple problems. 302 4 barrel eddlbrock-weber. Car is in park. Stomp on gas and the car dies. Problem 2: Intermitent stalling while driving. Does it when car is cold and when car is warmed up. I'm thinking something is wrong with the carb. Bought car this way no previous history. Any good ideas welcomed.
Jamesmc5 is offline   Reply With Quote
Old 12-06-2004, 11:03 PM   #2
andrewespo
andrewespo's Avatar
Re: 68 mustang dies on hard acceleration
Your probably getting too much fuel and it's flooding the cylinders with fuel and not enough oxygen. Not fully sure but an idea.
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
andrewespo is offline   Reply With Quote
Old 12-10-2004, 01:58 AM   #3
carnut
carnut's Avatar
Clogged fuel filter? Clogged air filter? Carb need rebuild? Vacuum leak?
I may be a rat, but I ain't no snitch!
carnut is offline   Reply With Quote
Old 12-16-2004, 11:48 PM   #4
Jamesmc5
Has new fuel filter. Has new K&N air filter. Has new eddlbrock carb. And its intermitent. Vacuum leak would be constant. Thanks for the ideas. I will still double check for a vacuum leak.
Old 12-17-2004, 12:43 AM   #5
ranger5002
check your coil
ranger5002 is offline   Reply With Quote
Old 12-17-2004, 12:45 AM   #6
ranger5002
ignition or timing may need to advance
Old 12-17-2004, 12:47 AM   #7
ranger5002
their saying not enough air but i say not enough fuel
Old 06-22-2009, 10:09 PM   #8
bassman...
sounds like carb..,,,most likely the accelerator pump..
bassman... is offline   Reply With Quote
