| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
My 98 Mustang turn signal switch needs to be replaced. Any one have experience in doing this? Does the sterring wheel and airbag have to be pulled?
Escort guy
![]() Join Date: Dec 2004
Re: 98 Mustang Turn Signal Switch
Welcome to AF!
You have 2 clam shell halves on your column. Check underneath for phillips screws. If you can get the clam shell halves off you won't need to pull the steering wheel. So check down there first. This is the way the multi-function switch is on my Escort. It may be the same on your Mustang. |
I see the screws that take the clam shells apart. The ignition switch also needs removed, how does it come out?
Escort guy
Not sure on your Mustang but on mine you disconnect the electrical connection, remove the 2 screws from the ignition key reminder switch and remove the ignition switch mounting screws.
Thanks for all the info. I was able to replace the switch today in about an hour.
Escort guy
Thanks for your reply. Glad you got it fixed. ~Dave~
| Tags |
| oes |
