Go Back   Automotive Forums .com Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 06-03-2009, 03:42 PM   #1
santiagountouched
mini me swap idle problem
i just completed a mini me swap on a 92 lx with a d15b block and a d16z6 head. a/t i used the ecu from the car i got the head from and the engine harness. it starts fine but once you drive and come to a stop it looses power, idles real low almost dies. ive replaced plugs wires rebuilt dizzy fuel filter pcv still dosent fix it. also it will eventually catch but you have to slam the gas to the floor then it will come back. i need help please ive been reading up and trying everything! thanks
santiagountouched is offline   Reply With Quote
Old 07-19-2009, 06:57 PM   #2
Honda V-Tec
Re: mini me swap idle problem
Start the engine and tap on the IACV with a screw driver. If it changes idle, replace it. I suspect thats whats wrong with mine. IACV are like 200 dollars from autozone but you can get them between 30-90 on Ebay.
Honda V-Tec is offline   Reply With Quote
Old 07-22-2009, 04:58 PM   #3
santiagountouched
found that the timing was off just 1 tooth. evrything is good now. i did clean the iac valve too that helped thanks.
