Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 05-24-2009, 06:57 PM
johnnybhai johnnybhai is offline
Question 93 Altima wont start
The battery is fine/new.
I checked the voltage on the device that had a coil inside it - in front of the engine, to the left of it as I am facing the front of the car (starter? alternator?) and that was 12V as well. So I think the connections are fine. Does that mean the starter is broken? What do I need to check next?
I also opened up the ignition switch area of the car, near the steering wheel well - but I am not sure what to check in there to see if the ignition switch is broken. Is there any way I can get a diagram of the wires in that area, to see what should go where - to determine if anything's loose.
Thanks a lot for all your assistance.
Old 05-29-2009, 07:09 PM
Re: 93 Altima wont start
bump
Old 06-27-2009, 11:56 PM
x1gary's Avatar
x1gary x1gary is offline
Send a message via AIM to x1gary Send a message via MSN to x1gary Send a message via Yahoo to x1gary
Do you hear a click when you try and start the car? It may be the starter... try and tap it with a hammer while someone is starting the car.
Altima G
