how do you paint metal?
i have a turbo i stripped off a nissan and i have cleaned it of all its caked on carbon so now its time to paint. i have some black high temp spray paint called engine enamel, i used it on a small peice(the oil flange) and it just rolls off and looks like crap. how do people get metal to look good spray painted?
Will primer stick to the turbo?
isnt primer just silver spray paint?
You will need an adhesion promoter, I would assume. Then put primer over that... but don't know if it's necessary.
thats alot of heat for your normal can of paint to stay on there..
:twoguns:"shepworldwide":twoguns: 96 integra for sale or trade huge northest meet may 31st. come check it out. |
so you want to paint ehhh
well you have to clean it that is the first step, since you are dealing with meatal i would highly recamend a fine steel wool or a dremel. after you clean it hit it with some paint thiner and then wash it off or clean it off. then you must primer, i would use a rustoleum metal primer, and then you can paint, usualy do 2-3 coats at least and then clear coat to protect the shiat
:smoker2:kaytec4door:smoker2: mods done: AEM cold air intake, ractive racing cat, ractive axel back exhaust, NGK plugs, nuespeed cross-drilled rotors, EBC the green stuff pads, projecter headlights, clear corners, carbon fiber tails, Z3 fenders, adjustable coilovers, Konig flatline rims with dunlop fm901 (17*7), full complete sound system with two 10'' subs, kenwood 600w amp, punch cap, pionner speakers all the way around, full custom interior paint job, reverse indiglo guages, aluminum gauge bezel, d16a6 head swap polished, 4-2-1 ceramic coated header, :finger4: proud member of team kay tec:finger4: |
Nicely put :-)
1997 Integra GSR and 1992 Civic LX |
and you don't really need primer, just lightly scuff up the fucker with some sand paper and then spray it with engine paint.
2000 BMW 323IT 1954 Ford F100 With every post my penis grows smaller Yakima Valley Truck Club Yakima Washington |
