used bcm 98 caravan
anyone know if i match #'s on bcm 98 caravan will it work without setting alarm off?i have factory anti theft but not the smart key type did they make two types of anti theft in 1998 i heard that if you install bcm from car with smart key to car with out smart key it will trigger alarm mode and shut down the powertrain module that i am trying to avoid i do not care about the mileage that will be in the new (Used) bcm it is a work van that i will junk when done with #on my bcm 04801062ad also read somewhere that the ad part of number refers to the firmware that is in the bcm it also has a date of june 03 on it so it must have been updated at one time. maybe they disabled the smart key function then the reason i know it is not smart key is they key would not turn one day at work. and I had to due bypass surgery on the ign to make it home been using screwdriver scince then to start any help thanks
Banned
![]() Join Date: Dec 2004
Re: used bcm 98 caravan
Chrysler's BCM's are only programed once with the vin burned in and they are done.You cannot get the programed and the only option is to get a new one and it has to be programed with the DRB III.
#3 | ||
![]() Join Date: Jul 2005
![]() The only way I think there would be a problem is if the donor vehicle had the alarm "armed" when it was junked. Also fyi, the replacement unit I got had the same part number but the last digit was an "E" instead of a "D", so you might be right about the firmware revision. |
