Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 02-10-2008, 04:10 PM
vw754 vw754 is offline
Abs ?
Renault clio dynamique,when i slow down some times brakes are fine,but have noticed on a few times that the 'abs' kicks in when it shouldnt,even at normal braking when coming to a stop--say at the traffic lights?
Old 03-13-2009, 06:48 AM
badboi clio badboi clio is offline
Re: Abs ?
ive got a 02 clio extreme and have this problem, i can start the car and drive it to the end of my road which takes a whole ten seconds, come to a stop at the bottom but with the abs on???? :S havent got a clue what this is, the only thing i think it could be it brake dust or wet and damp disks and pads, maybe? if you find out let me know. cheers
Old 03-29-2010, 05:10 PM
stevie68 stevie68 is offline
Re: Abs ?
i had a similar problem what it turned out to be was a cracked abs ring these are easily removed all you have to do is remove the road wheels and wire brush the rings these are located behind the wheel and have a look if you find a cracked one disconnect the drive and the ring can be tapped off the drive
