Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 04-26-2010, 09:33 AM
robbyaube2 robbyaube2 is offline
Front Passenger Knocking
Hello,
I have noticed a knocking on the front passenger side of our Van when hitting bumps. It was worst before I changed the hub and I thought the loose bearing was the cause but it appears that there is still something loose causing the noise... The Tie rod ball joint and lower ball joints appear to be tight when I pull them but it's hard to say... is there anything else that could cause this such as the strut mount or something like that???
Thanks,
Robby
Old 09-15-2010, 05:27 PM
spaceinvadertoo spaceinvadertoo is offline
Re: Front Passenger Knocking
Mine did this for several months until I serendipitously (blind luck) found the wing nut holding the spare tire onto the (storage area) mounting stud was loose, allowing the spare tire/wheel to flop around and bang against the bottom rear of the body. I have no idea why the noise was coming from the front passenger side, but after I ran the wing nut up tight to hold the spare against the underside of the car, the thumping noise stopped.
Old 09-21-2010, 12:08 AM
cretan cretan is offline
Originally Posted by robbyaube2 View Post
Hello,
Thanks,
Robby
That sound is usually means the sway bar links are worn out.mine went at about 50000 kilometers.Try that.
