Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 03-16-2009, 03:25 PM
GLFarnes's Avatar
GLFarnes GLFarnes is offline
Thumbs down Replaced Distributor FUBAR
I'm working on the 92 Bravada from hell again. I replaced a rusted out distributor with a new one and went through the standard installation. When I try to time it, the engine runs at about a thousand RPMs when its ten or so degrees retarded. When I bring it to zero the engine stutters and quits.
Any Ideas?
GL
Astro Vans are the best snow buggies in Alaska.
1992 Bravada 4.3 Vortec Auto
1998 Astro 4.3 Vortec Auto
2000 Astro 4.3 Vortec Auto
Old 03-16-2009, 05:02 PM
old_master's Avatar
old_master old_master is offline
Advisor/Moderator
Re: Replaced Distributor FUBAR
The EST wire must be disconnected while adjusting the timing. It's a tan wire with a black stripe located behind the carpet on the passenger side, directly below the glove box, near the side kick panel. It's a single wire with a black connector.
You have to know how it works,
to figure out why it doesn't.
Old 03-16-2009, 05:32 PM
GLFarnes's Avatar
Thanks, I'll give it a try when I get off work tonight.
GL
