Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 02-23-2009, 08:46 PM   #1
natekid13
1990 Camry acceleration problems
I have a 1990 Toyota Camry approaching 200,000 miles. Recently every time I accelerate past 15 mph my car starts shaking from half a second up to a few seconds. Also when I turn the wheel, it has become harder to turn and makes a whining noise when turned. At a stop, or once parked, I see smoke or steam rising from under the hood.
Could this be due to the fact that it is pretty cold out or is there a larger more substantial problem? Please if anyone could help i would appreciate it.
natekid13 is offline   Reply With Quote
Old 02-25-2009, 12:45 PM   #2
jdmccright
The RustBuster
jdmccright's Avatar
Re: 1990 Camry acceleration problems
First off, welcome to AF!
I'll address the symptoms separately:
Shaking can be caused by many different things. Does the shaking stop after the car shifts into a higher gear? Does it gradually go away? Does it get worse as speed increases? Does it stop or get worse when you step on the brakes? Is it worse when you are turning left or right? I know it's a lot of questions, but pinpointing when it shakes can help deduce what is wrong.
A whining noise while turning usually means your power steering fluid is low. Your Camry probably uses Dexron III automatic transmission fluid (ATF) for the power steering fluid. Check the reservoir level and add as needed. If it is completely empty, you likely have air in the system and will have to work out the air over time...check, fill, drive, repeat. If it's been run low for a long time, a power steering flush wouldn't hurt to get the old, overworked fluid out. If that doesn't stop the whining, then the power steering pump may have been damaged from running the system on empty too long.
Smoke or steam while at a standstill are two different things burning...oil or coolant. Each smells different when burned...oil is acrid and coolant smells sweet. Common oil leak places are the valve cover gasket and the oil cooler hose o-rings inside and just underneath the oil filter. You'd see oil dribbling (or its remnants) down the front of the engine from the oil filter base...I know because it's happened to me...easy and cheap fix but the seals you have to get from the dealer. From the smoke you describe, my bet is on an oil leak from here.
Common coolant leak places are the upper radiator hose to the block on the driver's side. If you see leakage on the passenger side near the wheel, you may have a dying water pump. Also, there is a small coolant tube that goes up to the throttle body. Whitish deposits on the engine just below this indicate a leak there.
The cold weather can affect the power steering since it isn't warmed up by the engine directly, so it can feel sluggish until the pump's shearing action can get it warmed up.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 02-25-2009, 09:00 PM   #3
natekid13
Firstly thanks for the welcome!
The shaking does indeed stop pretty much right after 15. It kicks into a higher gear and stops the shaking. No matter if its straight or turning.
I'll check on the steering and then its oil burning
Old 02-27-2009, 12:25 PM   #4
jdmccright
The RustBuster
jdmccright's Avatar
Vibration while at idle or just accelerating from a stop can be due to cold engine mounts. The 4-cyl Camrys have a rep for it, espeically in colder weather when the rubber mounts become less pliable...very noticeable at a stop and in gear. But after nearly 20 years, they may be shot. There are 4 mounts: 1) main front, 2) main rear, 3) transmission (driver's side wheel well), 4) a torque control "dog bone" strut on the top passenger side (attaches to strut tower).
Excessive vibration can also come from neglected ingition system: worn out spark plugs, crusty cap and rotor terminals.
Finally, rough engine can be due to a clogged or faulty positive crankcase ventilation (PCV), idle air control (IAC), or exhaust gas recirculation (EGR) valves.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Tags
camry
