91 Lumina rear brake caliper won't adjust
Taking advice from various threads on this forum I've managed to finally replace the rear rotors on my 91 lumina and get the caliper piston cranked back in. Now the driver's side caliper won't adjust. Pumping the E-brake several times adjusts the passenger side fine, but watching the driver's side while a helper pumps the e-brake, I see the piston rotate out and then slide back in when the brake is released.
Two oddities occured when doing this side. First the piston head on the right side has a small seal in the center while this side does not have that seal -- there's a hole where the seal should be. Second, I had a fierce time getting the parking brake tang back on and while fiddling with it at one point brake fluid leaked out the back side of the caliper where the tang attaches. I've spent way too much time on this "little job" and need to get done. Do I need to replace the missing seal? Rebuild the caliper? Punt and buy a new caliper? A side question is if I end up having to take this off again, is there a recommended way to get the spring and brake cable back on? |
A990 racer
![]() Join Date: Mar 2002
Re: 91 Lumina rear brake caliper won't adjust
Get another caliper they were troublesome from day one.
Registered Offender
![]() Join Date: Mar 2006
Not to pile on, but Max is correct. For people who don't routinely use the park brake, these calipers are problematic. The park brake actuator screw needs to be cleaned and lubricated with clean brake fluid. The lip seal must be in place.
I usually advise people to throw away the little square tool which is used to screw the piston back onto the actuator, and instead ratchet the actuator while pushing the piston straight back in. This will either free the actuator or reveal a stuck one. http://www.automotiveforums.com/vbul....php?p=5878362 I had numerous sets of these on several Fieros I owned, and they all worked just fine if they were maintained and used. I also have them on my old TA, and they work just fine, too. The best thing you can do is keep them clean and use the park brake regularly (as in every time you park).
The parking brake has been used regularly at least the last 3 years. The actuator and piston moved freely right from the start. The piston just doesn't stay in place. I wonder if I didn't get the lip seal properly positioned. As long as I'm taking it apart, that'll be an easy check.
----- The seal was indeed the problem, it apparently wasn't seated properly. Reseating it and ensuring the actuator screw was fully extended results in a fully working caliper. Making sure the parking brake was loose at the equalizer made attaching the cable and spring easier but still not as straight-forward as I would expect. Thanks guys. Last edited by Pablisimo; 01-02-2009 at 08:47 AM. |
#5 | ||
![]() Join Date: Feb 2009
Those calipers are a nightmare to work on and their sliding sleeves do get locked up. I think when you are removing them, you are suppose to release the tension at the parking brake equalizer, and instead of trying to turn the piston in take the rear parking brake lever off and run the piston in with a C-clamp with the brake pad still on to protect the plastic check valve and to square the piston in. I think trying to turn them in screws them up. They don't work like the Japanese calipers.
#7 | ||
These pistons do need to be turned in. There are several techniques recommended on the forum for doing this. I ended up using the Auto Zone "Borrow a tool" program which got me the mechanic's grade tool on loan for a refundable deposit. Cranks the piston back in seconds. |
#8 | ||
I unscrew ONE nut on each caliper; pull off ONE washer on each caliper along with the park brake lever. Then I push the piston back in with a C-clamp vice grip. The park brake screw spins instead of the piston, while the piston slides straight into the bore. Once the piston is back in the bore, I just re-attach the park brake cable, lever, washer, and nut. It could not be simpler, faster, or easier. I think rear-caliper problems on the W-body is an over-rated concern. I've got two Luminas; a '92 and a '93. The '92 was purchased in November, '92; the '93 I've only had for about three years. The '92 now has ~115K; the '93 has ~140K. I have had exactly Z-E-R-O problems with rear calipers other than routine pad changes. What I have had problems with are power boosters--I could use BOTH FEET on the brake pedal and push for all I was worth--and the cars would not stop hard enough to activate the anti-lock. Replacing boosters on both cars with standard, ordinary rebuilt units made a WORLD of difference.
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
#9 | |||
They are a pain to change pads on especially if you don't know how to do it though. You have to release the parking break tension, remove the parking braking lever, then push the piston in, then reinstall everything and readjust the parking break. That a lot of steps just to replace pads. there might be shortcuts like unboltening the rear parking breaking lever while it's still attache, but I'm not sure. A lot of other rear-calipers all you have to do is screw the piston in, and most new designs they separate the parking break from the caliper piston and all you have to do is press the piston in. |
