Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-29-2009, 10:19 PM
maxpsi maxpsi is offline
Angry 420a 2500-3500 Miss Under Load
95 eclipse n/t 420a mis at 2500 -3500 under load
new plugs wires fuel filter o and no codes
its run fine up to 2500 and after 3500 fuel psi is at 47at idle and 74 at 5200
i just got the car a week ago car has a cold air intake hotshot header o2 reading fine no misfire coil pack omhs fine tps omhs fine cam sen. looks like its reading fine (1g obd2 just slow ) . need help
Old 02-13-2009, 11:20 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
Re: 420a 2500-3500 Miss Under Load
What....the hell?
Try forming sentences man. It's really hard to understand anything except maybe that you're misfiring.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 02-16-2009, 08:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Your fuel pressure should not be that high. Get that fixed
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-16-2009, 02:43 PM
fuel pressure standard value is 46-49psi. i have a high fuel pressure due to 255lph pump and aeromotive fuel pressure regulator.
Old 02-16-2009, 05:03 PM
Holset powered 420a
If the car is NT why in the hell does it have a 255 fuel pump and a AFPR? Make sure the stock FPR is off the car. The 255 pump will overrun the stock FPR but the aeromotive one it will not so you have a problem there.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-17-2009, 07:47 PM
a new fuel pump is $142 a 255 is only $109 what would you buy?????----
I am not new to the 2G or the 1G so i know that im doing.
AFPR gos right in the stock port. So on that note fuel psi is fine. I`m thinking injecter. i have 660cc on the way and I have a trubo for this car but i have to fx the misfire. and yes the 660CC work fine on this car as a N/T
Old 02-17-2009, 08:08 PM
Holset powered 420a
The 255 pump will work fine with the AFPR but you had to buy that also which made the setup cost more than a stock pump. Still not a bad idea since you plan on going turbo. What do you plan on controlling the 660s with? The stock ECU wont controll them no matter how low you run the fuel pressure. You may be able to pull enough fuel with a SAFC or emanage if you run a super low base pressure. But then you may run into problems with the fuel not atomizing all the way.
No offince but it appears that you do not really know what you are doing. There is no reason to run that big of an injector unless your built and/or running megasquirt. I doubt this is the case but please inform us on what your goals are for the car.
Back on topic you should be getting a CEL for the missfire. If your not you could try checking the plugs and try to see which cylinder isin't firing and go from there.
98 Eclipse GS Turbo
2001 BMW 325i - DD
