bent valves and linkage pin
so idk if any of u guys know but my timing belt broke on my car. so i was gonna replace the timing belt. had alot of trouble with the center bolt, but i just turned up my compressor to 150psi and my 1/2 impact spun it off really easy. so i repace the belt and i try and start it, it doesnt start, so i do a comp check, found out #2,3 dont have any compression, so it looks like i bent the #2 intakes and #3 edxhaust valves, which sucks but i am doing a ls swap anyways so it doesnt matter. it looks like the belt broke because of the water pump, cause the water pump was gone.
so the other problem i am having is htat the damn shift linkage pin is driving me nuts. i was trying to use a gear puller to push it out, but i just ended up bending a creasten wrench. i think i am just gonna drill it out and get a bolt and nut thing in there. dah i am getting very frustrated. ok well thats it |
調整器
that sux
but at least ur problems and not mine hope u get that ls soon
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
RE: the linkage pin... Get a punch set from Sears; It's like US$7.
Todd 91 SI |
I would double check that you have the #1 cyclinder at TDC and make sure that your not off on the timing marks. Also how fast were you going when it broke ?
i got the pin out and i ended up breaking my gear puller. now another problem is that the linkage is still rusted stuck on the tranny
yeah i used a punch to get it out once my gear puller pushed it out alittle bit timing is right on, it was just at cruisin speed when it broke |
To get the linkage off the tranny heat it up a few times and use a hammer and put a bar or something on the lip of the linkage.
