| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
intake mani and TB?
so, i just spent a good hour reading people argue about whether or not its a good thing or a bad thing to add an intake mani and a TB to your 420a...
so i wanted to ask all of you trusty dsm'rs your opinions... with my mods...what would i realistically see in gains(or losses) across the board with an aftermarket intake manifold and throttle body?? also taking into account whether or not the benefits match the hassle..
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges |
Re: intake mani and TB?
As for the TB, get that bored to 55mm or 57mm. That should be fine.
does it make any difference if its bored or if i buy one aftermarket thats already that size?
dunno if there is anywhere around here to do much machine work where i live...=( at least not that i know of... i would just assume buy one and install...any probs with doing that?
Port and polish your intake manifold. Your also going to need to port out the opening where the TB bolts up. You can buy a bolt on TB and be good to go but they are a little on the expensive side. With your mods I would go to a 60mm TB. You can also buy one of these or do the jeep 60mm TB mod like I did. Total cost was like $25 for the jeep TB. Check 2gnt for a write up on the mod.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
I just want everyone that might search this to know this ithread is based on the 420A motor.
The 4g63 especially the 2g's are in a painful need of a freer flowing intake mani and tb in anything of excess of a s16g.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
60mm it is
recommend a good brand?
a throttle body really isn't that complicated a part. Its just a plate that opens and closes with a couple extra holes for some emissions and things. I would say just whatever fits and is cheap. I don't know which ones go on the 420a's no experience.
For the most part the 420a's use stock TBs. I honestly can't think of 1 aftermarket TB. Best bet is to get it bored out or go with the Jeep TB as Silver stated. Can pull them off junkyards for cheap.
The stock TB can not be bored past 57mm. There is one company that makes aftermarket TBs but I cant think of them off the top of my head. Search around some and you will find it. They are pricey though.
i founda good throttle body, i think it was 62mm
so any of you ever used/installed an aftermarket intake manifold?
I'm about to do both of them soon as the weather is plus anything
Dont even waste your time with your mod list on an aftermarket intake. Bore the TB sure, but 62mm? Overkill as hell. Aftermarket IM's, particularly the sheet metal ones, are only really power adders in the upper rpms and if memory serves they actually take away a lot of your low and mid range. Great if you're going to be running around the track at 6.5-9k constantly, but for every day use you're going to be basically making your car slower. Regardless, those are for big turbo guys running their stuff to the tits, and even if you were boosting the shit out of that little 16g and tracking it, I'd be suprised to see even a marginal gain.
I run a 60mm. A 62mm would be fine, there are not to many people that use aftermarket intakes on the 420a motor. And the ones that do I haven't even seen a dyno sheet showing the gain performance. I think its more of a show mod than anything.
I' m about to put on a 62mm tb too
