Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-24-2009, 06:50 PM
Tina King Tina King is offline
Send a message via AIM to Tina King
2000 Intrepid 2.7 Spark Plug problem
My husband changed the plugs in my 2000 Intrepid, it has a 2.7 in it. He pulled the #2 plug out and the end of the plug broke off in the hole. The elbow part and the round part in the middle are both inside the hole. He tried to fish it out with a magnet but it didn't work. Called a friend who has a shop and he said it should eventually come out the exhaust. So we went out and started it up and it there's a little "ping" noise now. Any suggestions would be appreciated.
Old 01-24-2009, 07:57 PM
discnik discnik is offline
Re: 2000 Intrepid 2.7 Spark Plug problem
The sound you hear is the piece of spark plug being bounced around inside the cyclinder. The thing is that these are an interference engine, which means the clearance between the piston and valves is very tight, so tight that if the timing chain were removed and the crank or cam shaft turned the piston will hit the valves.
My concern is that the little piece may cause damage to the valves.
If the ping does stop, piece gone, I would do a compression test on that cyclinder to insure no damage has occured to the valves.
